Hi All, I am trying to switch on the led for 8 seconds then I need to make it off for all the time using millis() but it doesn't work with me (Note that the led will on after 2 s from compilation) see the code bellow
const unsigned long event1=2000;
const unsigned long event2=10000;
pinMode(13,OUTPUT);
unsigned long currenttime=millis();
static bool state=true;
if ((state==true) && (currenttime >= event1)){
digitalWrite(13,HIGH);
state=!state;
if ((state==!state) && (currenttime >= event2)) {
digitalWrite(D7,LOW);
@mo7ammed-saleh your idea with the state and using the millis() value which starts at zero after power up is good. It only needs some work:
const unsigned long event1 = 2000UL;
const unsigned long event2 = 10000UL;
// state:
// 0 = idle, do nothing, there is even no code for that.
// 1 = led is off for 2 seconds, after startup
// 2 = led is on for 8 seconds.
int state = 0;
pinMode(LED_BUILTIN,OUTPUT);
state = 1; // go to first state (wait two seconds with led off)
if (state == 1 && currentMillis >= event1) {
digitalWrite(LED_BUILTIN,HIGH);
state = 2; // go to next state (wait 8 seconds with led on)
else if (state == 2 && currentMillis >= event2) {
digitalWrite(LED_BUILTIN,LOW);
state = 0; // go to idle state (there is not even code for it)
The sketch in Wokwi:
A normal millis-timer can be started at any moment. It can also be started in setup().
This is with a normal millis-timer:
unsigned long previousMillis;
unsigned long interval;
bool enable;
int ledState;
pinMode( LED_BUILTIN,OUTPUT);
// start millis timer
interval = 2000UL;
ledState = LOW;
enable = true;
if( enable)
if( currentMillis - previousMillis >= interval)
if( ledState == LOW)
ledState = HIGH; // set new led state
interval = 8000UL; // set new interval
ledState = LOW; // set new led state
enable = false; // stop own millis-timer
digitalWrite( LED_BUILTIN, ledState);
I will modify your code and try to explain. This is not tested but it's way too simple to need much debugging. Just remember Murphy's Law and that Murphy was an optimist!
const byte events = 2; // I use lots of space to make reading easier
byte nextEvent = 0;
const unsigned long event[ 2 ] = { 2000, 10000 }; // it becomes easy to add events
// now all events have the same name and a different number; event[0] and event[1]
const unsigned long ledOnDuration = 8000;
unsigned long currenttime; // allocate once, use often
{ // braces lined up on the page are easier to check balance { to }
pinMode( 13, OUTPUT ); // default LOW
currentTime = millis();
static bool pinState = false;
// Arduino clock is a big round clock with over 4 billion ticks before rollover.
// To make Time Calculations ALWAYS WORK THE SAME, unsigned subtraction
// of End minus Start always gives the time between.
// This arrangement watches for time from event begin and end, it's unusual.
// Note that when currentTime is event time -1 the subtract yields 4294967295ms,
// next tick the difference is zero.
// Also note that an if ( now - start == interval ) has a chance to miss the read
// and then next time may be 49.7-some days.
// So you test >= or <= or > or < with unsigned values, it takes care to be right
// but you learn more logic and math and arranging the problem to be easiest possible.
if ( currentTime - event[ nextEvent ] <= ledOnDuration )
if ( pinState == false )
pinState = true;
digitalWrite( 13, HIGH );
else if ( pinState == true )
pinState = false;
digitalWrite( 13, LOW );
if ( ++nextEvent > events ) nextEvent = 0; // will run again in 49 days
// it is a little clunky but see how easy to add events?
It would code cleaner as a series of OFF and ON periods. Then on even-number events the state to write is OFF, ON for odd number events, no longer need a pinState variable or a constant duration but do need twice the events.
You are writing without delays. The true power of Arduino will open to you, you can write code as independent tasks that run together and share data through variables.
The principles are simple, learn them with simple examples that you modify to test your understanding of going from general principle to specific application.
Have you debounced a button yet? A button can be as simple as a jumper you ground to "press". But Arduino is so fast it can read the button bounce 12 times in 2 milliseconds so it gets discussed, done and redone here in 20 ways or so. There's good conversations in the archives. It's like a rite of passage to write or choose a debounce.
