Please someone help me to write adruino codes for
Switch on LED if the LDR active for >=5 seconds. not immediately.
thanks.
thanks.
Not sure what you mean by the ldr being "active", although you might mean its reading is over or under some threshold?
Have a look at reply #4 here for a good clue.
spareProfile2:
Not sure what you mean by the ldr being "active", although you might mean its reading is over or under some threshold?Have a look at reply #4 here for a good clue.
chanaka2134:
Please someone help me to write adruino codes forSwitch on LED if the LDR active for >=5 seconds. not immediately.
Thank you for the help.
I am planing to create light sensitive switch with a LDR
I found codes which immediately switch on the LED once the LDR is in the dark.
const int ledpin = 12;
const int ldrpin = A0;void setup() {
Serial.begin(9600);pinMode(ledpin, OUTPUT);
pinMode(ldrpin, INPUT);}
int ldrStatus = analogRead(ldrpin);
if (ldrStatus >=600){
digitalWrite(ledpin, HIGH);
Serial.println(ldrStatus);
digitalWrite(ledpin,LOW);
}What i really need is to switch on the LED if the LDR in dark for more than 5 seconds duration.not immediately.
That is to avoid unnecessary switching on due to temporary shadows .
Thank you
So what you have to do:
hi,
you can use millis() function to do this.
eg.
if(millis() - time_to_switch_LED >= 5000)
//turn ON LED here.
time_to_switch_LED = millis();//reset time to zero for next cycle
also don't forget to declare --variable as
long time_to_switch_LED = 0;// in your code's setup
wvmarle:
- detect when the LDR reading drops below a certain value (see the state change detection example in the IDE)
- after some time switch on the LED (use the millis() timer).
Sorry, im just a beginner and this is my first arduino project. Thank you for your help.
dnyaneshvar:
hi,you can use millis() function to do this.
eg.
//turn ON LED here.time_to_switch_LED = millis();//reset time to zero for next cycle
Thank you for the help. i will try that. thanks
