switch, pointer to class containing enum
Hi mucking around with storing enums in a struct/class and trying to access the enum values through a pointer to the containing struct
the below code works and does what it is supposed to
class FOO
    private:
    public:
    int num = 0;
    struct st
        enum fooz{ONE, TWO}foo_st;
        int one;
        int two;
    }St;
}foo;
const struct State
    enum asd {qwe = 10, rty};
}*c;
void class_t()
    //foo.St.one = St.ONE;
    foo.num = foo.St.one;
    Serial.println(foo.St.one);
    Serial.println(foo.num);
    int rtger = c->asd::qwe;
    Serial.print("c->asd::qwe:");           Serial.println(c->asd::qwe);
    switch (rtger)
        case c->asd::qwe :
            Serial.print("in case:");           Serial.println(rtger);
        default:
i have another program im trying to do the same thing in but its coming up with errors saying the '.' and '->' arent allowed in the case statement.
is the above code a valid way of getting to the enum values, or did the code just get lucky
mucking around with storing enums in a struct/class and trying to call the enum values through a pointer to the containing struct
That doesn't make sense. You do not CALL values. You CALL functions. You ACCESS values.
It is, but it doesn't make sense to have the enum a member of a struct that is a member of a class.
Why didn't you post the code that you are having problems with?
  • because its spread across multiple
this is the example i was meaning to have a look at
const struct State
}*c;
is this switch statement valid
switch (rtger)
        case c->asd::qwe :
        default:
the first case???
here is some of the other code
class Enum_State
    enum Shp_Style { CIRCLE, SQUARE, RECT, SLOT };  // shape styles to chooses from
    enum Kerf_Off { CUT_INT = 0, CUT_EXT = 1 };             // internal or external kerf offsets
    enum Line_Style { LINE, ARC };                  // line styles to process
    enum Tool_Trav { TRAVEL, CUT };                 // tool traveling options
    enum Init_St { STOP, ACCEL, DECEL, RUN };       // initial section speed state
    enum End_St { DWELL, NONE, PEIRCE, HOME };      // end of section speed state
    enum Stpr_Dir { FOWARD, REVERSE, NO_MOVE };     // stepper lead screw direction states
    enum Shp_Cut_Dir { CW, CCW };                   // shape direction of cut travel
    // Mck ids, these values are used to be written directly into registers only or
    // bit shifted to get actual scaled number
    enum pwm_clk {
        PWM_MCK         = 0,
        PWM_MCK_2       = 1,
        PWM_MCK_4       = 2,
        PWM_MCK_8       = 3,
        PWM_MCK_16      = 4,
        PWM_MCK_32      = 5,
        PWM_MCK_64      = 6,
        PWM_MCK_128     = 7,
        PWM_MCK_256     = 8,
        PWM_MCK_512     = 9,
        PWM_MCK_1024    = 10
    enum stp_res {
        STP_M_RES       = 0,
        STP_M_RES_2     = 1,
        STP_M_RES_4     = 2,
        STP_M_RES_8     = 3,
        STP_M_RES_16    = 4,
        STP_M_RES_32    = 5
}extern state;
and the switch statements im having prouble with
void Shape::process_offsets()
{   // change dimensions(cut lines) to take care of kerf width
    float offset = 0.0;
    // choose offset direction
    switch(Imported.cut_offset_dir)
        case state.Kerf_Off::CUT_INT : offset = -(Imported.cut_offset * 2); break;
        case state.Kerf_Off::CUT_EXT : offset = (Imported.cut_offset * 2); break;
    switch (Imported.shape)
    {   // apply offsets dependent on shape (doesnt really matter what shape)
    case (state->Shp_Style::CIRCLE) :
        Imported.diameter_mm    += offset;
    case (state->Shp_Style::SQUARE) :
        Imported.width          += offset;
        Imported.height         = Imported.width;
    case (state->Shp_Style::RECT) :
        Imported.height         += offset;
    case (state->Shp_Style::SLOT) :
and the type of error im getting
Create_Shape.cpp: 45:26: error: '->' cannot appear in a constant-expression
   SQUARE)
Create_Shape.cpp: 50:8: error: 'state' cannot appear in a constant-expression
   RECT)
I do not like your style of defining structs and creating instances of them in one step.
Defining the struct/class is something that should happen in a header file. Defining the instances of the structs or classes is something that should happen in a source file.
state, as you have defined it now, is an object of type Enum_State. It is not a pointer, so using the pointer dereference operator, ->, is not appropriate. That is the first issue you need to resolve.
I can not see any value in putting all the enums in a class. The class has no functionality. A namespace MIGHT be appropriate, but a class is not.
cheers paul.
const struct State
}*c;
who new i always thought that was a declaration
namespace works but not as i would expect
namespace State
    enum class Shp_Style { CIRCLE, SQUARE, RECT, SLOT };    // shape styles to chooses from
and this is how it is working
USData.shape = State::RECT;
where as i thought you would access the enum like so
USData.shape = State::Shp_Style.RECT;
but im still getting the stupid '.' cant have the dot in a constant expression of the switch statement.
i read the standard and it says an enum class gets promoted to int type so it should work in a switch statement
this works well as far as readability goes, might stick with this approach, thanks for the namespace reminder, had all but forgotten about them
namespace Kerf_Offset {	// internal or external kerf offsets
	enum { internal, external };
};// end of Kerf_Offset
namespace Shp_Style {	// shape styles to chooses from
	enum { circle, square, rect, slot };
};// end of Shp_Style
namespace Line_Style {	// line styles to process
	enum { LINE, ARC };
};// end of Line_Style
I would put all the enums in one namespace. I would given them all names. Anonymous enums are hard to use.
namespace ENUMS
   enum Kerf_Offset {internal, external };
   enum Shp_Style { circle, square, rect, slot };
   // etc.
cheers what makes you say unnamed enums are harder to use than named versions
