Switch Rotary with LCD and LED
Hello everyone, i want to ask about my project. I use 1 Switch Rotary with 3 positions, 3 LED’s and 1 LCD. When i add “Ground” for pin 1 (LED and Switch Rotary) it can be works but the LCD can’t be show the text.
If i’m not add “Ground” for pin 1, the LCD can be show the text but LED and Switch Rotary can’t be work. (The LCD show the text with 3 conditions “Channel 1”, “Channel 2”, and “Channel 3” without controlled by Switch Rotary)
My goal : When i push the Switch Rotary in my desire, the LED can be light and the LCD can be show the text under controlled by Switch Rotary.
Here my project code :
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int switchPin = 1;
int Display = 0;
lcd.begin(16, 1);
pinMode(switchPin, INPUT);
digitalWrite(switchPin, HIGH);
if (digitalRead(switchPin) == HIGH){
delay(200);
Display ++;
if(Display > 4){
lcd.clear();
Display = 1;
switch (Display) {
case 1: {
lcd.setCursor(0, 0);
lcd.print(“Channel 1”);
case 2: {
lcd.clear();
lcd.print(“Channel 2”);
case 3: {
lcd.clear();
lcd.print(“Channel 3”);
How is the 3 position switch wired ?
A circuit diagram, even a hand drawn one, would help
When the “Ground” not add in Pin 1. (CTSSS 1.png)
When the “Ground” add in Pin 1. (CTSSS.png)
this is completely wrong
not ground pin 1 of arduino.
not use pin 1 of arduino for led (if you connect also to PC).
led is wired :
from "digital pin x" ;resistor 470 ohm; +led; -led; ground; when want to turn ON with "high" or
from "digital pin x" ;resistor 470 ohm; -led; +led; VCC; when want to turn ON with "low"
connect gnd of arduino to gnd of lcd and any other gnd of circuit
good luck
demkat1:
led is wired :
good luck
Okay thank you for your correction. So, how i can connected the LCD text with the Switch Rotary ? I'm confused with my project now :frowning:
take a look at tutorials for lcd (for example "hello world") and for connecting switches, leds etc to arduino.
take a look at examples (ide, file/examples/basics/DigitalReadSerial)
rintosw:
Examine the diagram below:
Wire your LEDs to separate Arduino pins, configured as outputs (not pins 0,1 !).
Wire each selector switch (SS) terminal to its own Arduino pin configured as input. If you configure them as INPUT_PULLUP then no external resistor is needed - S3 on the diagram. Wire the common of the SS to ground. If using external pullup wire as S2. You can also wire the inputs as S1* using *pulldown *resistors. In all cases each switch need its own pull up/down resistor.
Use the state of the inputs, combined with other code, to control the LEDs and control which message is printed to the LCD.
demkat1:
Okay, i will to try it, thank you.
dougp:
Wire each selector switch (SS) terminal to its own Arduino pin configured as input. If you configure them as INPUT_PULLUP then no external resistor is needed - S3 on the diagram. Wire the common of the SS to ground. If using external pullup wire as S2. You can also wire the inputs as S3 using *pulldown *resistors. In all cases each switch need its own pull up/down resistor.
Thank you, i will to try it now :slight_smile:
