Switch selection with buttons
Hello guys,
So, i wanna make this 3axis robotic arm.
Unfortunately, i don’t have joysticks. So i came out with this solution: 3 button to select the axis you want to move and a potentiometer to move.
I am experiencing problems with the selection part. So ideally, you would press a button, it would light up one of the three LEDs and the potentiometer would control the selected motor/axis. In my first version (messy af code) i got a do while loop in a switch to get the program controlling only one motor without running through the whole loop (and i think this is the way to go). But, when i pressed a button, it didn’t switch to controlling the other motor.
I feel like i am getting really close to the final, but this switching part isn’t working :confused: >:(
Anyone here got a solution ?
Thanks a lot ^^
Here is ver1 of the code
#include <Servo.h>
#include <Stepper.h>
#define STEPS 4096
Servo servo1;
Servo servo2;
Stepper stepper(STEPS, 2, 3, 4, 5);
int btn1 = 8;
int btn2 = 9;
int btn3 = 10;
int led1 = 11;
int led2 = 12;
int led3 = 13;
int servo1Position = 0;
int servo2Position = 0;
int btn1State = 0;
int btn2State = 0;
int btn3State = 0;
int previous = 0;
int switchstate = 0;
  servo1.attach(6);
  servo2.attach(7);
  pinMode(btn1, INPUT_PULLUP);
  pinMode(btn2, INPUT_PULLUP);
  pinMode(btn3, INPUT_PULLUP);
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
  pinMode(led3, OUTPUT);
  btn1State = digitalRead(btn1);
  btn2State = digitalRead(btn2);
  btn3State = digitalRead(btn3);
  if (btn1State == LOW && btn2State == HIGH && btn3State == HIGH) {
    switchstate = 1;
  } else if (btn1State == HIGH && btn2State == LOW && btn3State == HIGH) {
    switchstate = 2;
  } else if (btn1State == HIGH && btn2State == HIGH && btn3State == LOW) {
    switchstate = 3;
    switchstate = switchstate;
  switch (switchstate) {
    case 1:
      digitalWrite(led1, HIGH);
      digitalWrite(led2, LOW);
      digitalWrite(led3, LOW);
      Serial.println("1");
      int val = analogRead(A0);
      val = map(val, 0, 1023, 0, 180);
      servo1.write(val);
      delay(15);
    case 2:
      digitalWrite(led1, LOW);
      digitalWrite(led2, HIGH);
      Serial.println("2");
      servo2.write(val);
      delay(15);
    case 3:
      digitalWrite(led3, HIGH);
      Serial.println("3");
      stepper.step(val - previous);
      previous = val;
And here is ver2
#include <Servo.h>
#define STEPS 4096
Servo servo1;
Servo servo2;
int btn1 = 8;
int btn2 = 9;
int btn3 = 10;
int led1 = 11;
int led2 = 12;
int led3 = 13;
int btn1State = 0;
int btn2State = 0;
int btn3State = 0;
int previous = 0;
  servo1.attach(6);
  servo2.attach(7);
    switchstate = 1;
    switchstate = 2;
    switchstate = 3;
    case 1:
      servo1.write(val);
      delay(15);
    case 2:
      servo2.write(val);
      delay(15);
    case 3:
      previous = val;
What’s not working in version 2?
Well, when i press a button, it doesn't switch to the other LED and motor :confused:
Does the Serial monitor print the correct values?
it doesn't print anything :confused:
Does the sketch compile without errors?
Yup
Things don’t compile here without errors on version 2
This compiles and works:
#include <Servo.h>
#define STEPS 4096
Servo servo1;
Servo servo2;
int btn1 = 8;
int btn2 = 9;
int btn3 = 10;
int led1 = 11;
int led2 = 12;
int led3 = 13;
int btn1State = 0;
int btn2State = 0;
int btn3State = 0;
int previous = 0;
int val;
  servo1.attach(6);
  servo2.attach(7);
    switchstate = 1;
    switchstate = 2;
    switchstate = 3;
    case 1:
      servo1.write(val);
      delay(15);
    case 2:
      servo2.write(val);
      delay(15);
    case 3:
      previous = val;
Ok, thanks for that ^^
but i still don't know how to do that "selection" part (with the buttons) :slight_smile:
The code offered in post #7 works here, i.e. the switches, serial monitor and the LED portion.
Don’t have the motors so you will have to check those.
Oh f*ck myself lmao :slight_smile: :slight_smile: :smiley:
Thank you very much :slight_smile: ^^
