Hello!
I have two arduino boards, one with Wifi and one with Ethernet shield. I need some advice on getting the Wifi Arduino board to send the Switch statement to the Ethernet board that will be a web server. I have made some Wifi code, but I do not know what the code is to send the switch statement to the Webserver.
It Is not a big task for those who know the code, but for me It is. I want to press the switch button, and the server will output "Button pressed" or something, to indicate that the statement go from the Arduino board with Wifi to the Arduino board with ethernet and will work as a Web server. Please help.
Here is the code for the Client.
#include <SPI.h>
#include <WiFi.h>
char ssid[] = "Network"; // your network SSID (name)
char pass[] = "Password"; // your network password
// MAC address from Ethernet shield sticker under board
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(10, 0, 0, 20); // IP address, may need to change depending on network
WiFiServer server(80); // create a server at port 80
int status = WL_IDLE_STATUS;
//Initialize serial and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue:
while(true);
// attempt to connect to Wifi network:
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
server.begin();
// you're connected now, so print out the status:
printWifiStatus();
pinMode(3, INPUT); // input pin for switch
WiFiClient client = server.available(); // try to get client
if (client) { // got client?
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) { // client data available to read
char c = client.read(); // read 1 byte (character) from client
// last line of client request is blank and ends with \n
// respond to client only after last line received
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connnection: close");
client.println();
// send web page
client.println("<!DOCTYPE html>");
client.println("<html>");
client.println("<head>");
client.println("<title>Arduino Read Switch State</title>");
client.println("<meta http-equiv=\"refresh\" content=\"1\">");
client.println("</head>");
client.println("<body>");
client.println("<h1>Switch</h1>");
client.println("<p>State of switch is:</p>");
GetSwitchState(client);
client.println("</body>");
client.println("</html>");
// every line of text received from the client ends with \r\n
if (c == '\n') {
// last character on line of received text
// starting new line with next character read
else if (c != '\r') {
// a text character was received from client
currentLineIsBlank = false;
} // end if (client.available())
} // end while (client.connected())
delay(1); // give the web browser time to receive the data
client.stop(); // close the connection
} // end if (client)
void GetSwitchState(WiFiClient cl)
if (digitalRead(3)) {
cl.println("<p>ON</p>");
else {
cl.println("<p>OFF</p>");
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
