spycatcher2k:
You have an error on lines 4,23 and 65 of your sketch, I think! or possibly not, hard to tell without seeing it!
Here's the code:
//////////////PREPROCESSOR DIRECTIVES/////////
#include <Wire.h>
/////////////Function Prototypes//////////////
int menu();
/////////////GLOBAL VARIABLES////////////////
int SLAVEADDRESS = 0x08;
int REGISTERADDRESS = 0x1E;
int GATELOW = 0x00;
int GATEHIGH = 0x08;
////////////SETUP CONDITIONS/////////////////
Wire.setClock(3400000);
Wire.beginTransmission(byte(SLAVEADDRESS));
////////////MAIN FUNCTION///////////////////
int const CLOCKGEN= 1,
BANDGAP = 2,
GPIO = 3,
VBUS_COMP = 4,
VAC_COMP = 5,
ISNS_COMP = 6,
TSENSE_COMP = 7,
QR_COMP = 8,
ADC_ = 9,
MS_DRIVER = 10,
AC_DRIVER = 11,
ACTIVE_CLAMP_FET = 12;
int mainChoice;
//Prints main menu to the serial monitor
Serial.println("\t\t\t\t\t\t\t\t\t\t Select one of the following blocks to test: ");
Serial.print("\t\t\t\t\t\t\t\t\t\t\t\t (1) CLOCKGEN");
Serial.print("\t\t\t\t\t\t\t\t\t\t\t\t (2) BANDGAP");
Serial.print("\t\t\t\t\t\t\t\t\t\t\t\t (3) GPIO");
Serial.print("\t\t\t\t\t\t\t\t\t\t\t\t (4) VBUS_COMP");
Serial.print("\t\t\t\t\t\t\t\t\t\t\t\t (5) VAC_COMP");
Serial.print("\t\t\t\t\t\t\t\t\t\t\t\t (6) ISNS_COMP");
Serial.print("\t\t\t\t\t\t\t\t\t\t\t\t (7) TSNS_COMP");
Serial.print("\t\t\t\t\t\t\t\t\t\t\t\t (8) QR_COMP");
Serial.print("\t\t\t\t\t\t\t\t\t\t\t\t (9) ADC");
Serial.print("\t\t\t\t\t\t\t\t\t\t\t\t (10) MS_DRIVER");
Serial.print("\t\t\t\t\t\t\t\t\t\t\t\t (11) AC_DRIVER");
Serial.print("\t\t\t\t\t\t\t\t\t\t\t\t (12) ACTIVE_CLAMP_FET");
//empty while loop to hold until user enters a menu choice
while(Serial.available()==0)
mainChoice = Serial.parseInt();
switch (mainChoice)
case CLOCKGEN:
Serial.print("\t\t\t\t\t\t\t\t\t\t\t\t CLOCKGEN is not built out yet");
case BANDGAP:
Serial.print("\t\t\t\t\t\t\t\t\t\t\t\t BANDGAP is not built out yet");
case GPIO:
Serial.print("\t\t\t\t\t\t\t\t\t\t\t\t GPIO is not built out yet");
case VBUS_COMP:
Serial.print("\t\t\t\t\t\t\t\t\t\t\t\t VBUS_COMP is not built out yet");
case VAC_COMP:
Serial.print("\t\t\t\t\t\t\t\t\t\t\t\t VAC_COMP is not built out yet");
case ISNS_COMP:
Serial.print("\t\t\t\t\t\t\t\t\t\t\t\t ISNS_COMP is not built out yet");
case TSENSE_COMP:
Serial.print("\t\t\t\t\t\t\t\t\t\t\t\t TSENSE_COMP is not built out yet");
case QR_COMP:
Serial.print("\t\t\t\t\t\t\t\t\t\t\t\t QR_COMP is not built out yet");
case ADC_:
Serial.print("\t\t\t\t\t\t\t\t\t\t\t\t ADC is not built out yet");
case MS_DRIVER:
int msDriverChoice;
Serial.println("\t\t\t\t\t\t\t\t\t\t\t ******************************");
Serial.println("\t\t\t\t\t\t\t\t\t\t\t ** MS DRIVER MENU **");
Serial.println("\t\t\t\t\t\t\t\t\t\t Please enter your selection from the MS Driver menu below: ");
Serial.println("\t\t\t\t\t\t\t\t\t\t\t\t (1) MS VGATE HIGH ");
Serial.println("\t\t\t\t\t\t\t\t\t\t\t\t (2) MS VGATE LOW ");
Serial.println("\t\t\t\t\t\t\t\t\t\t\t\t (3) MS RPUP ");
Serial.println("\t\t\t\t\t\t\t\t\t\t\t\t (4) MS RPDN ");
Serial.println("\t\t\t\t\t\t\t\t\t\t\t\t (5) MS tRise ");
Serial.println("\t\t\t\t\t\t\t\t\t\t\t\t (6) MS tFall ");
Serial.println("\t\t\t\t\t\t\t\t\t\t\t\t (7) MS DRIVER PROP DELAY ");
Serial.println("\t\t\t\t\t\t\t\t\t\t\t\t (8) SW FREQ ");
Serial.println("\t\t\t\t\t\t\t\t\t\t\t\t (9) MS IQ 10V ACTIVE HIGH ");
while (Serial.available()==0){}
switch(msDriverChoice)
case AC_DRIVER:
Serial.print("\t\t\t\t\t\t\t\t\t\t\t\t AC_DRIVER is not built out yet");
case ACTIVE_CLAMP_FET:
Serial.print("\t\t\t\t\t\t\t\t\t\t\t\t ACTIVE_CLAMP is not built out yet");
