is the switch statement correct i can't seem to get it to work. i can see it gets into the while loop but does not start the switch statement
#include <PinChangeInterrupt.h>
#include <Wire.h>
#include <hd44780.h>
#include <hd44780ioClass/hd44780_I2Cexp.h>
hd44780_I2Cexp lcd;
// Const Variables and pin assinged
const byte ENC_SW = 3; // Encoder Switch
const byte ENC_PinA = 6; // PIN A of Encoder
const byte ENC_PinB = 8; // PIN B of Encoder
const byte buttonPin = 9; // Weld button
// Variables
byte prevENC_SWstate = HIGH;
byte ENC_SWstate = HIGH;
byte Inconfig; // Display config
int ENC_PinAState = LOW;
int ENC_PinALastState = LOW;
int Counter1;
unsigned long TimeStamp;
unsigned long ENC_SWpressDuration;
unsigned long delayTime = 50;
lcd.begin(16, 2);
lcd.clear();
pinMode(ENC_PinA, INPUT_PULLUP);
pinMode(ENC_PinB, INPUT_PULLUP);
pinMode(ENC_SW, INPUT_PULLUP);
attachPCINT(digitalPinToPCINT(ENC_PinA), rotaryEncoder, CHANGE);
lcd.setCursor(5, 0);
lcd.print("Start");
lcd.clear();
byte InMenu = false;
byte select;
lcd.setCursor(0, 0);
lcd.print("W1:10");
lcd.setCursor(0, 1);
lcd.print("W2:20");
lcd.setCursor(9, 0);
lcd.print("T:29");
lcd.setCursor(9, 1);
lcd.print("P:20");
lcd.print("%");
ENC_SWstate = digitalRead(ENC_SW);
if (ENC_SWstate == LOW && prevENC_SWstate == HIGH)
delay(20);
TimeStamp = millis();
if (ENC_SWstate == HIGH && prevENC_SWstate == LOW)
delay(20);
ENC_SWpressDuration = (millis() - TimeStamp);
if (ENC_SWpressDuration > 0 && ENC_SWpressDuration >= delayTime)
Inconfig = 1;
while (Inconfig == 1)
int select = 0;
select = readEncoder() % 4;
prevENC_SWstate = ENC_SWstate;
switch (select)
case1:
clearSelectPointer(1);
Serial.println(select);
lcd.print("<");
case2://W2
clearSelectPointer(2);
lcd.setCursor(5, 1);
lcd.print("<");
case3://P
clearSelectPointer(3);
lcd.setCursor(15, 1);
lcd.print("<");
Inconfig = 0;
void rotaryEncoder()
ENC_PinAState = digitalRead(ENC_PinA);
if (digitalRead(ENC_PinB) != ENC_PinAState)
Counter1--;
Counter1++;
int readEncoder()
noInterrupts();
int copyCounter = Counter1;
interrupts();
return (copyCounter) >> 1;
int clearSelectPointer(int checkPointer)
switch (checkPointer) {
case 1:// for select 1
lcd.setCursor(6, 1); // 2
lcd.print(" ");
lcd.setCursor(15, 1); // 3
lcd.print(" ");
case 2:// for select 2
lcd.setCursor(6, 0); // 1
lcd.print(" ");
lcd.print(" ");
case 3:// for select 3
lcd.print(" ");
lcd.print(" ");
