Switch statement not working..?
Hello,
First time on this forum (other then leeching from existing posts) :sweat_smile:
I have been working on a Arduino pro micro project for a while now, i added a display, joystick and 2 buttons and currently working on movement through the menu. however im running into a problem.
The problem i am encountering is that for some reason the switch statement is not working out the way its supposed to. it will only go into the case when action == 1 but when action >= 2 it skips the switch statement all together.
The piece of code giving me headaches:
  if (controller.obtainActions()) { // returns true or false depending on captured input
    byte tmpSelector;
    byte tmpState = 0;
    byte action = controller.returnAction(); //return a byte 0-6
    byte actionStrength = controller.returnStrength(); //return a byte 0-6
    if (debugJoystick) { Serial.println("Loop action  "+String(action)+" and strength is "+String(actionStrength)+" "); }
    if(inMenu()) { // bool inMenu() { bool val = false; if (loopState == 1) { val = true; } return val; }
      tmpSelector = menu.getMenuSelector(); // byte 0-6
      if (debugMenu) { Serial.println("Is inMenu()"); }
      if (debugMenu) { Serial.println("Has Action "+String(action)); }
      if (debugMenu) { Serial.println("Has Selector "+String(tmpSelector)); }
      switch(action) {
        case 1: // left
          if (debugMenu) { Serial.println("Case 1"); }
        case 2: // right
          if (debugMenu) { Serial.println("Case 2"); }
          if (debugMenu) { Serial.println("open submenu "); }
          //setState(tmpState); // sets isSubmenu() to true and isMenu() to false
        case 3: // up
          if (debugMenu) { Serial.println("Case 3"); }
          if (debugMenu) { Serial.println(F("menu up")); }
          menu.setMenuSelector(tmpSelector-1);
        case 4: // down
          if (debugMenu) { Serial.println("Case 4"); }
          if (debugMenu) { Serial.println(F("menu down")); }
          menu.setMenuSelector(tmpSelector+1);
        case 5: // left click
          if (debugMenu) { Serial.println("Case 5"); }
        case 6: // right click
          if (debugMenu) { Serial.println("Case 6"); }
        default:
          if (debugMenu) { Serial.println("Case Default"); }
      } // end switch action
When i run the code and press left (action 1) on the joystick it outputs the following text:
Loop action 1 and strength is 1
Is inMenu()
Has Action 1
Has Selector 1
Case 1
When action is above 1 (tested 2-6) it prints
Loop action 2 and strength is 1
Is inMenu()
Has Action 2
Has Selector 1
Is there anyone that may be able to sniff out the issue?
Greetings, Sneekyheart
In this case a code snippet won't do.
When you add in a Seril.println( action); right after the above line what numbers do you get?
When trying to add
Serial.println(action);
above the line
it has a compile error because action dous not exist.
ino:626:20: error: 'action' was not declared in this scope
Compilation error: exit status 1
controller.returnAction() will return a value between 0 and 6 after they are obtained by controller.obtainActions().
the action is printed by the following line and already incuded in the origional post:
Edit:
Just in case it peeks your interest, here is the class i wrote:
class SnController {
  public:
  SnController(byte pinX, byte pinY, byte pinL, byte pinR, bool debugging=false) { //initiate the object with correct pins.
    this->pinX = pinX;
    this->pinY = pinY;
    this->pinL = pinL;
    this->pinR = pinR;
    this->debugging = debugging;
    //possibly treshold ?
    //possibly debounce delay ?
  byte init() { //initialize the joystick by setting the correct pins
    pinMode(pinX, INPUT);
    pinMode(pinY, INPUT);
    pinMode(pinL, INPUT);
    pinMode(pinR, INPUT);
    //no checks for pinMode(pin, INPUT); so just say success lol
    return true; // just for fun
  bool obtainActions() { //returns true or false; obtain input and calculate if action is required
    float tmpStr = 1; // float because its range is 0-1024 and we want to round up with decimals //starting state as 1 because we unset strength if no input is given. this also allowes to capture movement when the remainder is too small for ceil (e.g. ceil(605) <= 0.002 == 0
    byte tmpAction = 0;
    //unset the return variables pre-hand to avoid issues (tbh its not needed, just a precaution)
      action = 0;
      actionStr = 0;
    // OBTAIN VOLTAGES OF INPUT HARDWARE and push it to State variables
    obtainVoltages();
    // INPUT DEBOUNCE TIMER SO WE DONT SPAM BUTTONS
    if (millis() - DebounceTime >= DebounceDelay) {
      // LEFT AND RIGHT ACTION
      if (stateX > XYinnerTreshold[1]) { // left
        tmpStr += ceil((stateX-XYinnerTreshold[1])/stepUp);
        tmpAction = 1; // left
      } else if (stateX < XYinnerTreshold[0]) { // right
        tmpStr += ceil((XYinnerTreshold[0]-stateX)/stepDown);
        tmpAction = 2; // right
      // UP AND DOWN ACTION
      } else if (stateY > XYinnerTreshold[1]) { // up
        tmpStr += ceil((stateY-XYinnerTreshold[1])/stepUp);
        tmpAction = 3; // up
      } else if (stateY < XYinnerTreshold[0]) { // down
        tmpStr += ceil((XYinnerTreshold[0]-stateY)/stepDown);
        tmpAction = 4; // down
      // LEFT AND RIGHT BUTTON
      } else if (stateL > ButtonTreshold ) {
        tmpAction = 5; // left button
        tmpStr = 1;
      } else if (stateR > ButtonTreshold ) {
        tmpAction = 6; // left button
        tmpStr = 1;
      // PUSH ANY CAPTURED ACTION AND STRENGTH TO STORAGE
      if (tmpAction >= 1) {
        // DISPLAY INFORMATION WHEN DEBUGGING IS TRUE
        if (debugging){
          Serial.println("Controller trigger obtained at "+String(millis())+" ms. ("+String(millis()-DebounceTime)+"ms since last input.");
          Serial.println("Action "+String(tmpAction)+" with "+tmpStr+" strength.");
        // RESET THE DEBOUNCE TIMER
        DebounceTime = millis();
        // PASS GENERATED DATA TO STORAGE
        action = tmpAction;
        actionStr = byte(tmpStr); // dont forget the convert the float to byte just in case..
        // RETURN TRUE IF A NEW ACTION IS OBTAINED
        return true;
      } else { // UNSET ACTION AND STR IF NOTHING COULD BE OBTAINED.
        return false;
        return false;
  // PUBLIC RETURN FUNCTIONS
  byte returnAction()   { return action; }
  byte returnStrength() { return actionStr; }
  bool isLeft()       { if (action == 1) { return true; } else { return false; } }
  bool isRight()      { if (action == 2) { return true; } else { return false; } }
  bool isUp()         { if (action == 3) { return true; } else { return false; } }
  bool isDown()       { if (action == 4) { return true; } else { return false; } }
  bool isLeftClick()  { if (action == 5) { return true; } else { return false; } }
  bool isRightClick() { if (action == 6) { return true; } else { return false; } }
  void tmpReturnState() {
    obtainVoltages();
    Serial.println("Controller state X: "+String(stateX)+"  state Y: "+String(stateY)+"    state L: "+String(stateL)+"    state R: "+String(stateR));
  private:
  // USER DEFINED OPTIONS
  bool debugging; // FOR PRINTLN DEBUGGING INFORMATION
  int XYinnerTreshold[2] = {350,600};
  int XYouterTreshold[2] = {0,1024};
  int ButtonTreshold = 950;
  long DebounceDelay = 300; // XX ms before registering a new trigger
  // VARIABLES FOR ARDUINO PINS
  byte pinX; // left right
  byte pinY; // up down
  byte pinL; // left btn
  byte pinR; // right btn
  // STORAGE TO SAVE THE LAST RECORDED VOLTAGE
  int stateX;
  int stateY;
  int stateL;
  int stateR;
  // STORAGE OF ACTION GENERATED BY LOOKING AT THE RAW VOLTAGE
  byte action; // where action == 1 = left, 2= right, 3 = up, 4 = down // used to store the action if any input is registered
  byte actionStr; // contains the strength used to trigger the joystick
  // STRENGTH STEPPER FOR INPUT
  int steps = 5; // amount of steps in movement strength (MAX 64)
  int stepDown = ceil(XYinnerTreshold[0]/steps);
  int stepUp = ceil((XYouterTreshold[1]-XYinnerTreshold[1])/steps);
  // sidequestion: dous this calculate every time the int is called or once at setup?
  // INPUT DEBOUNCE TIMER (ANTI BUTTON SPAM)
  long DebounceTime; // last registered time of trigger
  void obtainVoltages() { //obtain current voltage and push it to state storage
    int newReading[4];
    newReading[0] = analogRead(pinX);
    newReading[1] = analogRead(pinY);
    newReading[2] = analogRead(pinL);
    newReading[3] = analogRead(pinR);
    stateX = newReading[0];
    stateY = newReading[1];
    stateL = newReading[2];
    stateR = newReading[3];
}; // end of SnController
P.S. the class is a rudementry start; still have to clean things up and optimize things..
sorry for the double post; I have found the solution..
shouldve been
byte action;
Thanks @Idahowalker for pointing me in the right direction (if that was the point you were trying to make)
