Well still playing with led's max7219 and now I added a button... to change the led pattern. It seems to running to default only, as if my variable is not changing.
#include "binary.h" //Use this include for writing a byte in binary
#include "LedControl.h"//Use this include for controling LED's
const int buttonPin = 2;
const int dataPin = 11;
const int clockPin = 13;
const int devicePin = 10;
const int maxChips = 1;
int buttonVal = 0; //holds the number of times button was pushed.
int buttonState;
int lastState;
LedControl lc=LedControl(dataPin,clockPin,devicePin,maxChips);
lc.shutdown(0,false);
lc.setIntensity(0,8);
pinMode(buttonPin,INPUT);
buttonState = digitalRead(buttonPin);
if(buttonState == HIGH && lastState == LOW)
if(buttonVal > 3)
buttonVal == 0;
buttonVal++;
switch (buttonVal)
case 1:
lc.setRow(0,0,B01011000);
case 2:
lc.setRow(0,0,B00011111);
case 3:
lc.setRow(0,0,B10101010);
default:
lc.setRow(0,0,B11111111);
Well there it is, a nicer more professional looking format, using auto format, and I eliminated the obvious comments. Funny, now that I am getting the hang of it,, all comments seems obvious when you code properly.
I am not entirely sure, though I think it is ok, to put the buttonState bit in setup.
All help is appreciated from the experts out there. I have learned lots and will keep on learning.
Thank you in advance for any and all help.
LOL @ Gammon. Thanks for the link. I did a few tweaks, however results are still the same. I even made a buttonCount function to no avail. New code as follows.
int buttonState;
int lastState;
buttonCount();
switch (buttonVal)
case 1:
case 2:
case 3:
default:
void buttonCount()
if(buttonVal > 3)
buttonVal = 0;
buttonVal++;
I did some changes, followed the advice best as I understood, and it still is only reading default.
buttonCount();
switch (buttonVal)
case 1:
case 2:
case 3:
default:
void buttonCount()
static int buttonState;
if(buttonState == HIGH )
if(buttonVal > 3)
buttonVal = digitalRead(buttonPin);
buttonVal++;
if this is correct then it leads me to believe I have actually hooked up the switch wrong somehow. I will see about posting a schematic, thought it will be hand drawn since I do not have tools to draw such.
Alright I got it fixed,,,,, wasn't it to my surprise, every button press down and every release is a "HIGH" I was for some reason expecting down (closed switch) as HIGH and up(openswitch)as LOW. This is not the case. Interesting. Thanks for the help everyone... now to complicate it a little for me... more buttons, more combinations.
EDIT: wanted to post the code
const byte buttonPin = 2;
int buttonState = 0;
int lastState = 0;
int buttonVal = 0;
if (buttonState != lastState)
if(buttonState == HIGH)
buttonVal++;
if (buttonVal > 3)
buttonVal = 0;
switch (buttonVal)
case 1:
lc.setRow(0,0,B00000001);
case 2:
lc.setRow(0,0,B00000011);
case 3:
lc.setRow(0,0,B00000111);
default:
lc.setRow(0,0,B00000000);
lastState = buttonState ;
Unlikely, as this would imply that the button is on when pressed and on when not pressed. Either you have a very odd piece of hardware or something else is going on.
