Switch statements not working on some boards
I've written a library for sending short messages from one device to another (with addressing and checksums)
I have tested the library on an Adafruit Feather M0, sending data between two UART instances, and it works fine.
Now I am using it on an ATTiny 3227 with the MegaTinyCore, and a SAMD21 board with the Mattairtech core and the code has stopped working. In my update function it reads the latest serial byte and then has a switch statement with the various parser states for incoming data. This switch statement never executes even when valid data arrives. If I replace the switch with a series of if/else statements the code works.
I'm at a complete loss as to why the code would fail like this on two different boards when it works fine on a third.
The update function from my class is below, it prints out incoming data to confirm that the data is arriving but the switch statement doesn't execute. A commented out if/else statement is there and when I uncomment it I get ">Start2" printed out, indicating that the first byte of incoming data is accepted by the parser.
I'm not even close to the flash or ram limits of any of the devices I am using.
This is not the first time I have had relatively simple switch statements fail on Arduino boards and I am not getting any compiler warnings (with verbose messages on)
Am I missing some subtle bug here?
bool MicroMessage::update(){
	//returns true of a new packet was accepted - including if the packet has failed the checksum
	bool returnState = false;
	int inByte;
	//Data available? If not then check the timeout
	if(port->available()){
		inByte = port->read();
	}else{
		checkTimeout();
		//timeout will reset the parser
		return returnState;
	#ifdef MESSAGE_TIMING_DEBUG
		commRxStart = micros();
	#endif
	#ifdef PRINT_BYTES_IN
		//Incoming data is printed here just fine!
		Serial.print(inByte);
		Serial.print(" ");
	#endif
	//THESE IF/ELSE STATEMENTS WORK FINE
	if(commRXState == COMM_IDLE){
		if(inByte == PACKET_START_A) commRXState = READING_START2;
	}else if(commRXState == READING_START2){
		#ifdef PARSER_DEBUG
				debug.println(">Start2");
		#endif
		if(inByte == PACKET_START_B) commRXState = READING_START3;
		else commRXState = COMM_IDLE;
	//THIS SWITCH STATEMENT WILL NOT EXECUTE ON SOME BOARDS
	switch(commRXState){
		case COMM_IDLE:
		case READING_START2:
			#ifdef PARSER_DEBUG
			#endif
		case READING_START3:
			#ifdef PARSER_DEBUG
				debug.println(">Start3");
			#endif
			if(inByte == PACKET_START_A) commRXState = READING_START4;
		case READING_START4:
			#ifdef PARSER_DEBUG
				debug.println(">Start4");
			#endif
			if(inByte == PACKET_START_B) commRXState = READING_GROUP_ID;
		case READING_GROUP_ID:
			#ifdef PARSER_DEBUG
				debug.println(">group");
			#endif
			if( checkGroup((uint8_t)inByte) ){
				crc.add( (uint8_t)inByte );
				commRXState = READING_NODE_ID;
			else resetBuffer(RESET_REJECTED_GROUP);
		case READING_NODE_ID:
			#ifdef PARSER_DEBUG
				debug.println(">node");
			#endif
			if( checkNode((uint8_t)inByte) ){
				commRXState = READING_COMMAND;
			else resetBuffer(RESET_REJECTED_NODE);
		case READING_COMMAND:
			#ifdef PARSER_DEBUG
				debug.println(">command");
			#endif
			commandIn = (uint8_t)inByte;
			crc.add(commandIn);
			commRXState = READING_PACKET_LENGTH;
		case READING_PACKET_LENGTH:
			#ifdef PARSER_DEBUG
				debug.println(">packet length");
			#endif
			packetLengthIn = (uint8_t)inByte;
			crc.add(packetLengthIn);
			if(packetLengthIn == 0) commRXState = READING_CHECKSUM;
			else commRXState = READING_DATA;
		case READING_DATA:
			#ifdef PARSER_DEBUG
				debug.println(">data");
			#endif
			if(addToBuffer((uint8_t)inByte)) commRXState = READING_CHECKSUM;
		case READING_CHECKSUM:
			#ifdef PARSER_DEBUG
				debug.println(">checksum");
			#endif
			checksumIn = (uint8_t)inByte;
			checksumOKFlag = verifyChecksum();
			resetBuffer(RESET_DATA_OK);
				commRxEnd = micros();
				MESSAGE_TIMING_DEBUG debug.print("RxStart ");
				MESSAGE_TIMING_DEBUG debug.print(commRxStart);
				MESSAGE_TIMING_DEBUG debug.print(" RxEnd ");
				MESSAGE_TIMING_DEBUG debug.print(commRxEnd);
				MESSAGE_TIMING_DEBUG debug.print(" elapsed ");
				MESSAGE_TIMING_DEBUG debug.println(commRxEnd - commRxStart);
			#endif
			returnState = true;
		default:
			#ifdef PARSER_DEBUG
				debug.println("UNKNOWN STATE");
			#endif
  return returnState;
Please provide all the code, however long.
very likely your bug is not where you are looking at or showing us.
make a small compileable example which shows that error. The chances are high you will find the bug on your own. If not - post a full compileable example.
what does MESSAGE_TIMING_DEBUG look like? curious about that part
#endif
(if a macro defines a local variable outside a compound statement block in a switch, then you have a issue with the switch/case and are out of spec)
MESSAGE_TIMING_DEBUG:
Yeah, thats a really stupid error on my part. This is what it should be like, but correcting it has no impact on the problem.
#endif
is it just a
#define MESSAGE_TIMING_DEBUG
that you comment out or is there some value attached to the #define?
a quick test to see if there is a compound statement issue would be to add pairs of {} everywhere in the cases
  switch (commRXState) {
    case COMM_IDLE: {
        if (inByte == PACKET_START_A) commRXState = READING_START2;
    case READING_START2: {
#ifdef PARSER_DEBUG
#endif
        if (inByte == PACKET_START_B) commRXState = READING_START3;
    case READING_START3: {
#ifdef PARSER_DEBUG
#endif
        if (inByte == PACKET_START_A) commRXState = READING_START4;
Yes, this is what usually happens when I run out of ideas and ask for help on a forum - I suddenly find that the real problem was somewhere else!
This method checks to see if too much time has elapsed between bytes when recieving a message, and resets if the delay was too long.
There are occasional gaps between bytes of just over 10ms which I can't explain. There don't appear to be any delays when transmitting ...
void  MicroMessage::checkTimeout(commRXState_t st){
	//If there is no data
	unsigned long currentTime = micros();
	if(((currentTime - lastTime) < timeoutInterval)) return;
	if(st > COMM_IDLE) {
		timeoutErrors++;
		#ifdef TIMEOUT_DEBUG
			debug.print("Message Timeout:");
			//debug.print("Timeout:");
			debug.println((currentTime - lastTime));
			//debug.print((uint8_t)commRXState);
			//debug.println(" in parser");
		#endif
			#endif
		resetBuffer(RESET_TIMEOUT);
	} else  resetBuffer(RESET_NORMAL);
  lastTime = micros();
That sounds close to Rubber duck debugging - Wikipedia
Yup, and it seems to have worked. I've now ironed out all the bugs and the code is working really nicely.
