HI
Sorry if this is 101 basic question.
Can you have a switch statement that use "<" operators as I would like to write the code without if else statements if possible.
Switch (Var)
Case <1999:
\ do something
Case <2999
\ do something
ect ect
Please can you advise if this is possible and how to achieve this.
Don't try to use switch for things it isn't designed for. Contrary to other languages like SQL, switch isn't necessarily translated by the compiler to a set of if statements, thus what you want to do doesn't work with switch. The correct syntax for your problem is:
if (var < 199) {
// do something;
else if (var < 299) {
// do something;
else if (var < 399) {
// do something;
else {
// do whatever
If formatted and indented properly, this is just as readable as a switch block.
