I have a switch structure which runs different actions based on a volatile variable, which is updated by an interruption when a button (pin 3) is pressed.
The problem is that the action linked to the value 3 (WIPER_WASH, so the last before the "default:" in the code) actually never runs even if wiperState is 3 : the debug code before the switch statement correctly prints out "three" (so wiperState is actually 3), but the case linked to this value is never run. Putting a Serial.println("test"); inside the not working case shows it never runs since "test" is never printed out.
// Define constants
// Pins
#define BTN_PIN 3
#define SERVO_PIN 11
#define POT_PIN A0
#define LED_PIN 9
// Values
#define WIPER_OFF 0
#define WIPER_ON 1
#define WIPER_INTERMITTENT 2
#define WIPER_WASH 3
// Debug
#define debug 1
// Include libs
#include <Servo.h> // include the Servo lib
// Instanciate objects
Servo wiper;
// Declare global variables
// Volatile because used in an interruption
volatile int wiperState = WIPER_OFF;
int delayTime = 0;
void switchWiperState() {
// Switches between states. OFF -> ON -> INTERMITTENT -> WASH -> OFF (reset
// inside the loop function)
// Autre option : array contenant les états, ou bien un if.
wiperState = (wiperState+1);
void wiperCycle(int downDelay = 1000) {
wiper.write(179);
wiper.write(0);
delay(downDelay);
// Debug code
#if debug
#endif
// Declare/attach pins
pinMode(BTN_PIN, INPUT);
pinMode(LED_PIN, OUTPUT);
wiper.attach(SERVO_PIN);
// Initialisation
wiper.write(0);
// Interruptions
attachInterrupt(digitalPinToInterrupt(3), switchWiperState, RISING);
if(wiperState > 3) {
wiperState = 0;
#if debug
if(wiperState == 0) {
Serial.println("zero");
if(wiperState == 1) {
Serial.println("one");
if(wiperState == 2) {
Serial.println("two");
if(wiperState == 3) {
Serial.println("three");
#endif
switch(wiperState) {
// when the wiper is off, move it down ant let it still
case WIPER_OFF:
wiper.write(0);
// when the wiper is on, move it up and down successively
case WIPER_ON:
wiperCycle();
// when the wiper is in intermittent mode, move it up and down successively but
// while waiting a delay time choosen based on the potentiometer value
case WIPER_INTERMITTENT:
int delayTime = map(analogRead(POT_PIN), 0, 1023, 1000, 3000);
wiperCycle(delayTime);
// when the wiper is in wash mode, we wash the windshield and then go back to off mode
case WIPER_WASH:
// turn on the wiper fluid
digitalWrite(LED_PIN, HIGH);
// wipe 5 times
for(int i=0; i < 3; i++) {
wiperCycle();
// turn off wiper fluid
digitalWrite(LED_PIN, LOW);
wiperState = 0;
delay(0);
default:
And strangely, switching the order of the last case and the before-last case (so defining case WIPER_STATE before case WIPER_INTERMITTENT) makes it work perfectly, all the cases are correctly executed according to what the user asked.
I'm using an Arduino UNO R3, the one given in the student kit.
Thanks by advance for any clue,
