Switch to flip LEDs
Hi Guys,
I'm very new to programming and arduino and I'm learning off the examples, youtube, books etc.
At the moment I'm trying to build a custom controller for a device I have.
So, lets say I got two row of switches, each with two switch and every switch has a LED.
I can flick between LEDs in each individual rows. Now I want to add a fifth button which flicks between the active LEDs in each row.
Lets say:
In row one I got LED 2 on
In row two I got LED 1 on
I want to have a switch that when I press turns Row1,LED1 ON. Row2,LED2 ON and all others off.
If you know the concept of vision mixers row 1 is my programme and row 2 is my preview and the fifth switch is the "take" button (and thats what I'm making!)
#define DEBOUNCE 10                     // Debaounse tims
#define NUMBUTTONS 4                   // Number of toal buttons in the console
  // BUTTONS
  byte buttons [] = {2, 3, 4, 5};
  // LEDS
  byte ledPin [] = {8, 9, 10, 11};
   #define NUMBUTTONS sizeof(buttons)
byte pressed[NUMBUTTONS], justpressed[NUMBUTTONS], justreleased[NUMBUTTONS];
byte previous_keystate[NUMBUTTONS], current_keystate[NUMBUTTONS];
  byte i;
  Serial.print("Console V1 with ");
  Serial.print(NUMBUTTONS, DEC);
  Serial.println(" buttons");
  // pin13 LED
  pinMode(13, OUTPUT);
    for (i=0; i< NUMBUTTONS; i++) {
    pinMode(buttons[i], INPUT);
    digitalWrite(buttons[i], HIGH);
    pinMode(ledPin[i], OUTPUT);
  byte thisSwitch=thisSwitch_justPressed();
  switch(thisSwitch)
  case 0:
    setLedStatus(ledPin[0],1,0);break;
  case 1:
    setLedStatus(ledPin[1],2,0); break;
  case 2:
    setLedStatus(ledPin[2],3,2); break;
  case 3:
    setLedStatus(ledPin[3],4,2); break;
     void check_switches(){
  static byte previousstate[NUMBUTTONS];
  static byte currentstate[NUMBUTTONS];
  static long lasttime;
  byte index;
  byte previousswitch;
  if (millis() < lasttime) {
    // we wrapped around, lets just try again
    lasttime = millis();
  if ((lasttime + DEBOUNCE) > millis()) {
    // not enough time has passed to debounce
    return;
  // ok we have waited DEBOUNCE milliseconds, lets reset the timer
  for (index = 0; index < NUMBUTTONS; index++) {
    justpressed[index] = 0;       //when we start, we clear out the "just" indicators
    justreleased[index] = 0;
    currentstate[index] = digitalRead(buttons[index]);   //read the button
    if (currentstate[index] == previousstate[index]) {
      if ((pressed[index] == LOW) && (currentstate[index] == LOW)) {
        // just pressed
        justpressed[index] = 1;
        previousswitch = justpressed[index];
      else if ((pressed[index] == HIGH) && (currentstate[index] == HIGH)) {
        justreleased[index] = 1; // just released
      pressed[index] = !currentstate[index];
    previousstate[index] = currentstate[index];
byte thisSwitch_justPressed() {
  byte thisSwitch = 255;
  check_switches();  //check the switches &amp; get the current state
  for (byte i = 0; i < NUMBUTTONS; i++) {
    current_keystate[i]=justpressed[i];
    if (current_keystate[i] != previous_keystate[i]) {
      if (current_keystate[i]) thisSwitch=i;
    previous_keystate[i]=current_keystate[i];
//  r-> last_pressed = "s1";
  return thisSwitch;
 byte setLedStatus(byte activeLed, byte activeButton, byte activeRow){ // This function sets the active switch's LED on, and turn the other ones off
  for (int thisPin = 0; thisPin < NUMBUTTONS/2; thisPin++)  {
   digitalWrite(ledPin[thisPin+activeRow], LOW);
     digitalWrite(activeLed, HIGH);
     Serial.print("switch ");
     Serial.print(activeButton);
     Serial.println(" just pressed");
This code worked fine I just have no Idea how to add the functionality that I need to it!
Many thanks,
Sep
Just to see if I understood, you have 4 LEDs, 4 Switches.
If you Press a Switch, the corresponding LED invert it's state (ON>>OFF or OFF>>ON).
And you need another switch to invert all LEDs states.
Is this correct?
