You have more than one variable named ctrlchg1, each with their own scope
You declare it once at the start of the program which gives it global scope so remove the int from all other occurrences of it to stop a new version of it being declared
Hello
I got tired of lecturing about debouncing buttons and finite state machines tonight, so I added the changes to your sketch. The sketch is untested and may need to be adapted to your MIDI environment.
#include <MIDI.h>
MIDI_CREATE_DEFAULT_INSTANCE();
Serial.begin(31250);
MIDI.begin (MIDI_CHANNEL_OMNI); // Launch MIDI and listen to channel omni
pinMode(2, INPUT_PULLUP);
static bool state = 0;
static int stage = 0;
static unsigned long buttonMillis;
const unsigned long buttondelay = 50;
if (millis() - buttonMillis >= buttondelay) {
buttonMillis = millis();
bool pinState = !digitalRead(2);
if (state != pinState) {
state = pinState;
if (state) {
switch (stage) {
case 0:
MIDI.sendControlChange(12, 0, 1);
case 1:
MIDI.sendControlChange(12, 127, 1);
stage++;
stage = stage % 2;
