Hi all,
I’ve been struggling with this for the past 4 hours and thought I’d come here begging for help…
So I’m basically trying to set up two different sets of messages based on the moisture level reading (“avg”) which are to be toggled back and forth by a momentary switch. My method right now is to have the switches toggle an LED which in turn toggles a set of messages… This is proving to be incredibly frustrating as nothing I’ve been trying is working.
Do you guys have any ideas for an easier way to do this? I know I’m not doing this the right way… Thank you so much ahead of time to anyone who lends an eye! :*
#define voltageFlipPin1 2
#define voltageFlipPin2 4
#define sensorPin 0
#include <SoftwareSerial.h> // we need to include this library !
#define rxPin 30 // rxPin is immaterial - not used - just make this an unused Arduino pin number
#define txPin A2 // txPin is the one needed for the LCD - we'll use Digital Pin A0/14 to send serial data to the LCD
// mySerial is connected to the TX pin so mySerial.print commands are used
// one could just as well use the software mySerial library to communicate on another pin
// we're using SoftwareSerial so that we can save pins 0&1 for the BUB
SoftwareSerial mySerial = SoftwareSerial(rxPin, txPin); // let SoftwareSerial know what pins we'll use
int flipTimer = 500;
const int SWITCH = 6; //pin 2 for switch input
const int LED = 12; //pin 13 for led output
//create variables
boolean toggle;
int switchState;
void setup(){
//false means the led is off (boolean are either 0 or 1)
toggle = false;
//set pin modes
pinMode(SWITCH, INPUT);
pinMode(LED, OUTPUT);
pinMode(voltageFlipPin1, OUTPUT);
pinMode(voltageFlipPin2, OUTPUT);
pinMode(sensorPin, INPUT);
pinMode(txPin, OUTPUT);
mySerial.begin(9600); // 9600 baud is chip communications speed
delay(80); // pause to allow LCD EEPROM to
mySerial.print("?G216"); // set to LCD display geometry, 2 x 16 characters in this case
delay(80); // pause to allow LCD EEPROM to program
mySerial.print("?Bff"); // set backlight to ff hex, maximum brightness (you can change this!)
void setSensorPolarity(boolean flip){
if(flip){
digitalWrite(voltageFlipPin1, HIGH);
digitalWrite(voltageFlipPin2, LOW);
}else{
digitalWrite(voltageFlipPin1, LOW);
digitalWrite(voltageFlipPin2, HIGH);
void loop(){
setSensorPolarity(true);
delay(flipTimer);
int val1 = analogRead(sensorPin);
delay(flipTimer);
setSensorPolarity(false);
delay(flipTimer);
// invert the reading
int val2 = 1023 - analogRead(sensorPin);
reportLevels(val1,val2);
void reportLevels(int val1,int val2){
int avg = (val1 + val2) / 2;
String msg = "avg: ";
msg += avg;
Serial.println(msg);
switchState = digitalRead(SWITCH); //check switch
while(switchState == HIGH){
switchState = digitalRead(SWITCH);//double check
if(switchState == LOW){
toggle = !toggle;
digitalWrite(LED, toggle);
break; //exit
mySerial.print("?f");
delay(30);
while ( switchState == HIGH ){
if ( avg <= 50 ){
mySerial.print("AAAAA");
delay(5000);
delay(30);
else if ( avg <= 150 && avg > 50 ){
mySerial.print("BBBBB");
delay(5000);
delay(30);
else if ( avg <= 350 && avg > 150 ){
mySerial.print("CCCCC");
delay(5000);
delay(30);
while ( switchState == LOW ){
if ( avg <= 50 ){
mySerial.print("11111");
delay(5000);
delay(30);
mySerial.print("22222");
delay(5000);
delay(30);
mySerial.print("33333");
delay(5000);
delay(30);
