Switch with an integer
int k;
k=10;
switch(k){
case((k>=0)&&(k<=5)) Serial.println(“Type : Sur_Longueur”);break;
case((k>=6)&&(k<=10)) Serial.println("Type : Fixe ");break;
case((k>=11)&&(k<=20)) Serial.println(“Type : Sur_Longueur”);break;
case((k>=21)&&(k<=27)) Serial.println(“Type : Fixe”);break;}
So , i get an error at the 4th case line “case((k>=21)&&(k<=27)) Serial.println(“Type : Fixe”);break;”
Error: the value of ‘k’ is not usable in a constant expression
How to fix this ?
Thanks
I think the test value in each 'case' clause must evaluate to a constant at compile time. Yours include a variable.
Please read this: https://www.arduino.cc/en/Reference/SwitchCase
gfvalvo: I think the test value in each 'case' clause must evaluate to a constant at compile time. Yours include a variable.
in each case, i need to check if the value of 'k' is withing that interval of integers or not.
khoubeib: in each case, i need to check if the value of 'k' is withing that interval of integers or not.
Then you'll probably have to do it a different way as I don't think ranges (even constant ones) are supported as the 'case' test conditions.
Actually, it may. Try:
  case const1 ... const2:
    //do stuff
  case const3 ... const4:
     // do stuff
Haven't tested it, but it does compile.
gfvalvo: Actually, it may. Try:
    //do stuff
  case const3 ... const4:     // do stuff     break;
Just tried it on an Emulator , it Works, Thanks Bro
if(k<=5)  Serial.println("Type : Sur_Longueur");
else if(k<=10)  Serial.println("Type : Fixe ");
else if(k<=20)    Serial.println("Type : Sur_Longueur");
else if(k<=27)    Serial.println("Type : Fixe");
OR
if(k >=0 && k <=27) {
  switch((k+4) / 5) {
    case 0:
    case 1:
    case 3:
    case 4:
    case 2:
    case 5:
OR:
  if(((k+4) / 5) % 3 < 2)
Although that last one might be a little obscure.
khoubeib: Just tried it on an Emulator , it Works
That's not an approach I'd get used to relying on.
A little? Code is supposed to be easy to understand, like your first example. The others require (varying amounts of) more study, and cause a lot of WTF moments.
KISS still applies.
Just for the record, the "..." is a GCC extension, and might not be portable. You should comment it as such. You also need to be careful with spaces: "2 ... 12" will work "2...12" might not since "2.." is an invalid floating point constant.
