Switch
What happens with break in case in switch ?
Control is transferred out of the switch block
thank you, but when we run the code and enter that case it runs the next one as well
Well then, maybe you should show us your sketch :wink:
Use CTRL T to format your code.
Attach your ‘complete’ sketch between code tags, use the </> icon in the posting menu.
[code]Paste your sketch here[/code]
marta99judo:
You got a problem then
Thoughts and prayers.
#include <TM1637Display.h>
#include <TimerOne.h>
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 10
#define RST_PIN 7
String inputString = "";
int stanje = -1;
int voltage = 0;
const int crvenaL = 3;
const int zelenaL = 4;
const int trigPin = 5;
const int echoPin = 6;
const int touchPin = 2;
volatile byte state = LOW;
const int CLK = 9; //Set the CLK pin connection to the display
const int DIO = 8; //Set the DIO pin connection to the display
long trajanje;
int rastojanje;
int br = 0;
int N;
boolean unutra = false;
boolean prva_vrata = false;
boolean druga_vrata = false;
String procitano = "";
MFRC522 mfrc522(SS_PIN, RST_PIN);
TM1637Display display(CLK, DIO);
  pinMode(zelenaL, OUTPUT);
  pinMode(crvenaL, OUTPUT);
  digitalWrite(crvenaL, LOW);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  pinMode(touchPin, INPUT_PULLUP);
  br = 0;
  unutra = false;
  Serial.begin(9600);   // Initiate a serial communication
  SPI.begin();      // Initiate  SPI bus
  mfrc522.PCD_Init();   // Initiate MFRC522
  attachInterrupt(digitalPinToInterrupt(touchPin), ksd, CHANGE);
  Timer1.attachInterrupt(timerIsr);
  Timer1.initialize(1000000);
  display.setBrightness(7);
void serialEvent() {
  while (Serial.available()) {
    char inChar = (char)Serial.read();
    if (inChar == '\n' && inputString.length() > 0) {
      procitano = inputString;
      stanje = procitano.toInt();
      inputString = "";
    else {
      inputString += inChar;
  display.showNumberDec(br);
  Serial.println('#' + String(br));
  //  if ((unutra == false) && (br<N)) {
  // Da li ima novih kartica?
  if ( ! mfrc522.PICC_IsNewCardPresent())
    return;
  // Proverava da li je moguće pročitati ID kartice
  if ( ! mfrc522.PICC_ReadCardSerial())
    return;
  //Prikaz ID
  String content = "";
  for (byte i = 0; i < mfrc522.uid.size; i++)
    content.concat(String(mfrc522.uid.uidByte[i], HEX));
    content.concat(" ");
  Serial.println(content);
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  trajanje = pulseIn(echoPin, HIGH);
  rastojanje = trajanje * 0.034 / 2;
  switch (stanje) {
    case (0):
      digitalWrite(zelenaL, LOW);
      digitalWrite(crvenaL, HIGH);
    case (1):
      prva_vrata = true;
      unutra = true;
      if (rastojanje < 10) {
        prva_vrata = false;
        if (state == HIGH) {
          digitalWrite(zelenaL, HIGH);
          druga_vrata = true;
          unutra = false;
          br = br + 1;
    case (2):
      br = br - 1;
    default:
void ksd() {
  state = HIGH;
void timerIsr()
  int N = 4 * analogRead(A0);
  Serial.println('
  • String(N));
switch (var) {
  case label1:
    // statements
  case label2:
    // statements
  default:
    // statements
Note
case (0);
shouldn’t it be?
case 0;
Tom… :slight_smile:
TomGeorge:
Note
case (0);
shouldn't it be?
case 0;
Tom... :slight_smile:
It just has to be a compile-time constant integer expression. "(0)" meets the requirement.
