I got the following Code which works, but not like intended, it should ask me for a password after pressing 1 on the 4x4 Keypad. Somehow it stops after "Serial.print(Taste);" and I have no idea why.
What I want my programm to do:
If I press 1 on the Keypad it should execute Case 1, which is powering a LED and asking me for a password that also gets typed in over the Keypad
#include <Keypad.h>
#define LED1 10
//Hier wird die größe des Keypads definiert
const byte COLS = 4; //4 Spalten
const byte ROWS = 4; //4 Zeilen
//Die Ziffern und Zeichen des Keypads werden eingegeben:
char hexaKeys[ROWS][COLS] = {
{'D', '#', '0', '*'},
{'C', '9', '8', '7'},
{'B', '6', '5', '4'},
{'A', '3', '2', '1'}
byte colPins[COLS] = {2, 3, 4, 5}; //Definition der Pins für die 4 Spalten
byte rowPins[ROWS] = {6, 7, 8, 9}; //Definition der Pins für die 4 Zeilen
char Taste; //Taste ist die Variable für die jeweils gedrückte Taste.
Keypad Tastenfeld = Keypad(makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS); //Das Keypad kann absofort mit "Tastenfeld" angesprochen werden
const String password = "9999"; // change your password here
String input_password;
pinMode(10, OUTPUT);
char Taste = Tastenfeld.getKey();
if (Taste)
switch (Taste)
case '1':
digitalWrite(LED1, HIGH);
Serial.println("LED wurde angeschalten");
if (Taste == '1') {
Serial.println("Type Password");
input_password = ""; // clear input password
} else if (Taste == '#') {
if (password == input_password) {
Serial.println("password is correct");
// DO YOUR WORK HERE
Serial.println("password is incorrect, try again");
case '2':
digitalWrite(LED1, LOW);
Serial.println("Led wurde ausgeschalten");
switch (Taste)
case '1':
if (Taste == '1') {
➜ if you enter the first case, Taste is '1', how do you think it could be anything else magically afterwards since you did not change it? so your if is useless, there is no chance it can be '#' or anything else than '1'
First I created a flag to identify if the number 1 had already been typed.
Then I released save the password in string format only after the number 1 is typed.
I changed the structure of witch to create "a state machine".
PS:
I changed again the sketh removing an unnecessary if.
(if (Taste) ).
I've already posted the new version with this modification.
Here is an example I wrote a while back to do numeric passwords from keypad.
#include <Keypad.h>
// Combination is "08675309"
// Use any value up to 4 billion
// NOTE: 08675309 is not a valid number and will
// not compile. The leading zero means 'octal
// constant' and the digits 8 and 9 are not valid
// octal digits.
// To get leading zeroes, set CombinationLength
// higher than the number of digits
const unsigned long Combination = 8675309;
const byte CombinationLength = 8;
const byte ROWS = 4; // set four rows
const byte COLS = 4; // set four columns
const char keys[ROWS][COLS] = // Define the keymap
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
byte rowPins[ROWS] = { 36, 34, 32, 30 };
byte colPins[COLS] = { 28, 26, 24, 22 };
// Create the keypad
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS );
unsigned long InputValue = 0;
byte InputLength = 0;
pinMode(46, OUTPUT); // Set green LED as output
pinMode(48, OUTPUT); // Set red LED as output
char key = keypad.getKey();
switch (key)
case '*': // Clear
InputValue = 0;
InputLength = 0;
case '0'...'9':
InputValue *= 10;
InputLength++;
InputValue += key - '0';
case '#': // Enter
if (InputLength == CombinationLength && InputValue == Combination)
Serial.println("Success, Come inside"); // If the password is correct
digitalWrite(46, HIGH); // Turn on green LED
delay(500); // Wait 5 seconds
digitalWrite(46, LOW); // Turn off green LED
Serial.println("Access Denied"); // If the password is incorrect
digitalWrite(48, HIGH); // Turn on red LED
digitalWrite(48, LOW); // Turn off red LED
InputValue = 0;
InputLength = 0;
} // switch(key)
} // loop()
