I'm trying to do something that should be very straight forward. There may already be a module that nothing has to be done to it to do what I want arduino or something else even. I could do it with a series of relays and diodes, but don't really want to have the bulk.
I am ultimately wanting to power a fan that is either turned on by a motion sensor or a remote control.
I am almost sure that none of the off the shelf devices would like voltage coming backwards to an open circuit on the other switching source - especially when using ICs.
Before you do anything else...
Identify & purchase a mains-certified relay board, and enclosure to adequately isolate the mains voltage from the incidental world of fingers, children, pets and the environment.
The decide how you want to control it.
What you’re asking is trivial with an Arduino.
Perhaps forget the relays to start - switching LEDs until you get the logic right.
Then add the insulated relay module once it’s working.
If you need help on the first step, give it your best shot, post that here, and we can help you move forward.
On aliexpress this is totally enclosed and controlled by WiFi.
Features:
- Controlled by free APP named eFamilyCloud which can be downloaded on APP store and Google Play
- Remote control is more convenient: pick up your phone and easily remotely control almost all your home appliances anytime, anywhere. Take control of you thousands of miles away.
- Intelligent timing: scientific management of time, quality of life is guaranteed.
- Cycle timing, peace of mind: Let the device work automatically and periodically, without worrying about it.
- Delayed timing, life is more convenient: for any device without a timer, easy to add timing on/off function.
- Get rid of the remote control, multi-person sharing control: the main account exclusive sharing rights, can be shared with the whole family with one click.
- Six functions: mobile phone control, physical switch, intelligent timing, short circuit protection, one-click sharing, overload protection.
- Controlled by Voice, Working with Amazon Alexa echo and Google Home Can be used to control your own bedside lamp or kitchen light switch for voice control
sockets or small appliances that control electronic fireplaces, fans, air cleaners, humidifiers, aquarium oxygenators, and much more*
- Connected by 2.4G net work, 5G is not available(802.11 b/g/n)
750 ℃ anti-flame retardant shell, leakage protection.*
You could set up one group to turn on/turn off all the sockets
Amazon says : smart socket with app control Smart plug, Mini Wifi Outlet Compatible with Alexa, Google Home & IFTTT, No Hub Required, Remote Control your home appliances from Anywhere, ETL Certified (one Piece)
I have not seen Arduino support yet, but I just found this recently.
