int thermostat = A2;
int coil1 = 9;
int coil2 = 10;
int coil3 = 11;
int switchingtime;
int i;
void setup(){
pinMode(thermostat, INPUT);
pinMode(coil1, OUTPUT);
pinMode(coil2, OUTPUT);
pinMode(coil3, OUTPUT);
pinMode(LED_BUILTIN, OUTPUT);
delay(switchingtime);
switchingtime = 1000;
void loop(){
while (digitalRead(thermostat)== HIGH){
digitalWrite(LED_BUILTIN, LOW);
digitalWrite(coil1, HIGH);
digitalWrite(coil1,LOW);
digitalWrite(coil2, HIGH);
digitalWrite(coil2,LOW);
digitalWrite(coil3, HIGH);
digitalWrite(coil3,LOW);
return;
digitalWrite(LED_BUILTIN, HIGH);
return;
I'm trying to use it to drive a 12v fridge compressor i'm working on.
i plan to use a switched reluctance motor turning on and off it's coils attaching tips 120 to the 9,10, and 11 pins, wich i wish to turn on and off in order.
i have a push button acting as thermostat on pin A2. A real fridge thermostat is about to get fit there whenever i be able to build the rest of the hardware.
i have 3 leds representing coil1, coil2, and coil3.
It does work, but it does in a reverse manner.
While button is unpressed, LED_BUILTING should stay lit.
Whenever i depress button, pins 9,10 and 11 should start counting.
What did i do wrong here? I'm on arduino uno attached to this gnu/linux pc...
JCA34F, I suspect you meant A2. Still, why not use INPUT_PULLUP on A2's pin mode and then connect the other side of the switch to GND? Then change the while to LOW. That way, with the switch open, A2 will be guaranteed to be high and when pressed, it will be low.
PickyBiker:
I just did what you suggested and it works as intended!
just let me thank you for your support!
I just wish to add a safety measure. i need to make it to wait 120 seconds (two minutes) after depressing the "thermostat" switch , so it doesn't get damaged.
i tried to add a "delay" before doing anything but it just gets stuck. how can i do it?
Can i get LED_BUILTIN blinking after thermostat on / button so there's indication that motor is about to start?
I believe that a FOR line could be added, but it's my first Arduino project ever..
Please, see the successful source.. is this..
int thermostat = A1;
int coil1 = 9;
int coil2 = 10;
int coil3 = 11;
int switchingtime;
int switchinglenght;
int pressurerelieftime;
int i;
void setup(){
pinMode(thermostat, INPUT_PULLUP);
switchingtime = 0005;
switchinglenght = 0005;
pressurerelieftime = 10000;
void loop(){
while (digitalRead(thermostat)== LOW){
delay(switchinglenght);
return;
return;
I'm trying to drive a 3 coil switched reluctance motor.
I do have to turn on and off, in sequence, coil 1, coil 2 and coil 3.
I wish to use pins A1, A2, A3 and A4, sending them to ground by means of a resistor, to select the speed of it.
How can i do it?
You seem to be missing one important piece of the motor: "the switched-reluctance motor uses an electronic position sensor to determine the angle of the rotor shaft".
Trendset:
You referred in your other posting, to driving the coils with IIRC, TIP120s (not a good choice!). What does this speed selection do, and why do you refer to analog (input) pins?
Do be careful anyway about using A4, since it is what you need to use for I2C.
