Switches having a delay
I am working on a project where I'm trying to use a dip switch but for some reason I'm coming across a strange problem. turning the switch on works perfectly fine but when turning the switch off there is a delay of usually a few seconds. I have connected the dip switch from the 5V live on an Arduino Uno through a resistor then through the switch and finally back to a digital read pin. is there something wrong with that because I tried writing a separate code just to read the switch and I'm coming across the same thing.
for this graph I flipped the switch back at 340 exactly and the reading finally fell at 367.
the code was
  pinMode(3, INPUT);
  Serial.println(digitalRead(3));
I'm sorry if this is a dumb error, I'm really new to Arduino and I have no idea where to look to fix this.
Try:
pinMode(3, INPUT_PULLUP);
FYI
thank you so much, that works perfectly. I really appreciate the help.
Wiring switches as per S3 in the schematic is preferred as no external resistor is needed.
that makes a lot more sense. this had been bugging me for days now.
