I'm interested in switching 45-60v on and off using an arduino. I have 2 different scenarios....
Purely a switch. low current. Only hundreds of mA at most.
Switching higher current, about 20w (about 2A).
My options are opto-coupler, relay, mosfet. I'm unsure which of these would suit the job the best.
It needs to be battery efficient when in the default off/open state. And ideally compact, as I am working in a tight space.
Can anyone suggest which would be best for these different jobs?
@gibbz
I have used mosfets and solid state relays in those applications and both worked fine the mosfet will most likely be cheaper and more compact. Be careful in your mosfet selection. I have burned up {flames) more than one with high voltage capacitor discharge applications. Give the mosfet a try.
Lloyd-ss
@Paul_KD7HB
I have not run into the situation of needing 2 different grounds yet. How DO you isolate them to protect the Arduino (I guess that is the risk, correct?)?
Thanks,
Lloyd
Its dc, for a diy ebike project.
Arduino can share the same ground.
its 18-20 watt at 48v for the ebike lights.
I need to check how much space I have, relays are obviously easy. But I'm thinking I might give mosfets a try, as I'd like to try something new. Worst case scenario is cram in relays....
I wouldn't say relays being obviously easy. Common relays are rated up to 24-30 VDC max, beyond that there is risk of arching. DC-relays more than 24v are expensive, more than 48v are even difficult to find. Better to go with mosfet module or SSR for DC loads.
