I'm trying to use a P-channel MOSFET (FQP7P06) as a high-side switch to turn off power to my sensors/radio from a 3.3v ATmega328P.
The Vgs threshold is -2.0 to -4.0v according to the datasheet, the same as the FQP27P06 and FQP47P06.
The problem I'm having is that from a 3.3v supply its only putting out 1.9v so is barely even lighting an LED. From a 5v supply it lets through 4.93v as expected.
It shouldn't need a driver chip or transistor to run it as long as SOURCE and GATE differ by 2-4v, which they do as I can see on my mulimeter that the digital pin is switching between 0v and 3.3v.
Any ideas what the problem is here? Am I completely misunderstanding Vgs, rdsON etc? Do I need a different FET?
Yes but the threshold value is just that, the value when the FET just starts to turn on, it is not the value when it is turned on fully. To see that you have to look at the RDS(on) figure. This shows what the gate voltage is when the device is fully on. You will see that this is 10V, so you can't switch on this FET with your 3V3.
i knew you were going to say that. even at 5v it seemed a bit unsteady (LED was flickering almost unperceptably).
would a NDP6020P be better - VGS threshold is -0.4 to -1.0v and RDS(on) from 2.5-4.5v, its about the only one still on sale with those sort of specs, about a quid each:
my NDP6020P has arrived but things are behaving oddly.
i can see the voltage to my nrf24l01+ is flipping between 3.3v and about 0.8v (i'm a bit surprised that's not 0v) but what's odd is that after the first "power off" the radio never comes back on again. i can see the 328p has a constant 3.3v as that's not going via the mosfet.
if i comment out the code to set the digital pin high to turn off the power, everything runs ok.
i assume its something to do with the radio, as if i make a basic led circuit on breadboard the led goes on and off just fine.
fungus:
Why? The nrf24l01+ only consumes 900nA when you put it in standby.
i'm not convinced, that's datasheet speak for the chip alone, not measured by anyone in a circuit with pna/amp etc; as far as i know.
something in my circuit is eating 2xAA in a week, its not the MCU, so i'm powering off the bmp085, dht11, ds18b20 and nrf24l01+ using the mosfet (or trying to!)
MarkT:
So find out what it is with a multimeter....
easier said than done. that's not really the issue anyway, the issue is why doesn't the rf24 recover after being turned off with a mosfet. i think i've got it fixed now, got to test a bit longer but it seems to be as simple as calling the radio.begin() etc. in the loop
Some devices are sensitive to the speed with which the rail rises on switch on - using
a FET means the rail rises in a few us, rather than ms - you might find increasing the
gate resistor value could have some benefit here.
It may also be that the leakage current, which is keeping the modules supply at 0.8V
when "off", causes the device's reset/power-on detection circuit to malfunction. Add
a 10k resistor across the device's supply perhaps to pull that 0.8V down to millivolts.
fungus:
Five minutes with a multimeter and a switch will reveal the truth...
fungus:
for some odd reason none of my meters work as ammeters properly. and really it would be an utter cow to use a ammeter in a soldered circuit given that you have to connect in series.
any suggestions on a good ammeter that's not megabucks?
