Hi all
I've seen online various devices that offer capacitive touch light switches, (for example: Touch Panel Light Switch). These are capable of taking power from the live wire of an AC circuit whilst also switching it, by allowing a small amount of power to bleed through past the switch - but not enough to illuminate the bulb as the voltage is so low.
In switches where there is a neutral connection available, this is pretty straightforward; the problem arises where that's not the case and only the live connection is available.
There's a transformer on the control circuit to lower the voltage to a suitable level for logic circuits, and this is connected to either side of the relay. Simplified, it's like this:
I'd like to be able to do the same so that I can do something similar with an Arduino as part of a control circuit, but I can't seem to find any guidance anywhere on how to do this. Looking for some advice please that will allow me to proceed without having to power the Arduino circuit from a completely separate source...
Note: I'm aware of the hazards of working with mains electricity, and the need for proper isolation etc.
