Switching an Output to opposite to last status
I use the onboard LED on pin 13 as a simple visual monitor, to see that, 1; the program is running and 2; how fast the it get around the loop.
So I have a function like this:
void HeartBeat(void) { if (HeartBeatState>0) { digitalWrite(13,HIGH); HeartBeatState= 0; } else{ digitalWrite(13,LOW); HeartBeatState= 1; } return;
Is there a way to use XOR on the output ?
I guess my question really is: What is the fastest way of switching an output pin ?
Cheers
K
fiddler: I use the onboard LED on pin 13 as a simple visual monitor, to see that, 1; the program is running and 2; how fast the it get around the loop.
Cheers
K
I remember time ago someone asking for a DigitalWrite(TOGGLE); but I think it was never added. You can however use something like this:
boolean s;
void HeartBeat()
   digitalWrite(13,s=!s);
You can read outputs, so you could do.
digitalWrite(13, !digitalRead(13) );
Or you could have the hardware invert the pin by writing a 1 into the PIN instead of the PORT register.
Thanks guys, awesome :-)
fiddler: I guess my question really is: What is the fastest way of switching an output pin ?
How fast is fast enough? I find it hard to believe you're actually going to notice the LED switching frequency if you're calling this code frequently enough for performance to be an issue.
