Im trying to merge 3 of my sensors into one unit. The case is that I have 3 sensors that i want to use, but not at the same time. I would like to switch between them when needed.(pushbutton) I also need to adjust the sensitivity for the sensor with a potentiometer.
Could this be done with the arduiono switch case function?
What do you wnat to do with the data? Just display?
The sensor I am going to use is: light sensor, microphone, and a pir.
I have the code for light sensor and pir working already. The data from the sensor is going to trigger an event. IT does not need to be displayed.
So far i have not tried to merge the code into one. Want to get some feedback first.
And I am very new to the arduino
