switching between autonomus and manual
I’m using an Arduino Leonardo, and when i try to upload this program it keeps telling me: “steer declared as function returning a function.” this is my first year dealing with arduino, and i dont want to fail this course. Can anyone tell me what i am doing wrong?
Autonomus_and_RC.ino (2.66 KB)
Your code formatting is very odd.
{ void steer()
{ void loop()
The "{" should go after the function name and argument list. Anyway, use the code formatter tool in the Arduino IDE and then look at the indentation to see if it groups statements together as you would expect and then try to compile it. The error message you quoted was certainly one of a large number, only one of which was visible to you.
It looks like the MINDSi example you started with (AUV5ping) got badly mangled along the way. I would suggest starting over from the latest MINDSi library :
#include <Servo.h>
#include <MINDSi.h>
/ Example provided by MINDS-i
/ Try checking out our arduino resource guide at
/ http://mindsieducation.com/programming-resources
/ Questions? Concerns? Bugs? email code@mymindsi.com
/ This example expects an ESC plugged into pin 4
/ A servo plugged into pin 5
/ and ping sensors in pins 9, 10, and 11
/ optionally, IR sensors in pins 12 and 13
const bool IR_ENABLED    = false;
const int  CENTER        = 90;
const int  TURN          = 45;
const int  FWDSPEED      = 115;
const int  REVSPEED      = 70;
const int  BACKUP_TIME   = 2000;
const int  SIDE_RANGE    = 4000;
const int  PING_PINS[]   = {      7,      8,      9,     10,     11};
const int  HAZARD_DIST[] = {    650,    800,   3000,    800,    650};
const int                    WEST=0, LEFT=1,  FWD=2,RIGHT=3, EAST=4;
Servo drive, frontsteer, backsteer;
int ping[5];
  pinMode(13, INPUT);
  pinMode(12, INPUT);
  drive.attach(4);
  frontsteer.attach(5);
  backsteer.attach(6);
  // start interrupts on pin 3 so pulses will be captured before isRadioOn
  // is first called
  getRadio(3);
  steer(CENTER);
  drive.write(90);
  delay(2000);
//define a steer command that sets front and back servos
void steer(int out) {
  frontsteer.write(out);
  backsteer.write(180 - out);
  //this will give manual control if a radio is plugged in
  if (isRadioOn(3)) {
    drive.write(getRadio(2));
    steer(getRadio(3));
    autodrive();
void autodrive() {
  bool danger = false;
  for (int i = 0; i < 5; i++) {
    ping[i] = getPing(PING_PINS[i]);
    if (ping[i] < HAZARD_DIST[i]) danger = true;
    delay(10);
  if (danger) {
    //coast down for two seconds
    drive.write(90);
    delay(2000);
    //turn in the most favorable direction
    if (ping[LEFT] > ping[RIGHT]) {
      steer(CENTER + TURN);
      steer(CENTER - TURN);
    //prime reverse
    drive.write(85);
    delay(50);
    drive.write(90);
    delay(50);
    //back up for BACKUP_TIME milliseconds
    drive.write(REVSPEED);
    uint32_t endTime = millis() + BACKUP_TIME;
    while (millis() < endTime) {
      //leave the loop if backup sensors see a wall
      if ( IR_ENABLED && (!digitalRead(13) | !digitalRead(12)) ) break;
    //coast to a stop
    drive.write(90);
    steer(CENTER);
  else {
    //calculate average distance on each side
    long left  = min(ping[LEFT] , ping[WEST]);
    long right = min(ping[RIGHT], ping[EAST]);
    left  = constrain(left , 0, SIDE_RANGE);
    right = constrain(right, 0, SIDE_RANGE);
    //map the difference in lAve and rAve from +/- SIDE_RANGE to +/- TURN
    long steerValue = map( (left - right),
                           -SIDE_RANGE, SIDE_RANGE,
                           -TURN,       TURN);
    steer(CENTER - steerValue);
    drive.write(FWDSPEED);
johnwasser:
#include <Servo.h>
#include <MINDSi.h>
const int  PING_PINS   = {      7,      8,      9,     10,     11};
const int  HAZARD_DIST = {    650,    800,   3000,    800,    650};
int ping[5];
pinMode(13, INPUT);
 pinMode(12, INPUT);
drive.attach(4);
 // is first called
 getRadio(3);
steer(CENTER);
 drive.write(90);
 delay(2000);
 if (isRadioOn(3)) {
   steer(getRadio(3));
   autodrive();
void autodrive() {
   delay(10);
if (danger) {
   drive.write(90);
   delay(2000);
//prime reverse
   drive.write(85);
   delay(50);
   drive.write(90);
   delay(50);
//coast to a stop
   drive.write(90);
   steer(CENTER);
 else {
                          -TURN,       TURN);
Is this JUST the AUV5Ping? how do i bind both the controller functions and the autonomus controls to the Rover?
