Switching between LED sequences
Sorry, did'ent think about it...
byte ledPins[] = {
  5,   6,   7,   8};
void light1(){
byte ledLighting[7][4] = {
    1,   1,   1,   1    }
    0,   0,   0,   0    }
    0,   0,   0,   1    }
    0,   0,   1,   1    }
    0,   1,   1,   1    }
    1,   1,   1,   1    }
    0,   0,   0,   0    }
int ledMillis[7][4] = {
    1000,  500, 500, 500    }
    1000,    0,   0,   0    }
    500,    0,   0,   0    }
    500,    0,   0,   0    }
    500,    0,   0,   0    }
    500,    0,   0,   0    }
    1000,    0,   0,   0    }
void light2(){
byte ledLighting2[7][4] = {
    1,   1,   1,   1    }
    0,   0,   0,   0    }
    1,   0,   0,   1    }
    0,   0,   1,   1    }
    0,   1,   1,   1    }
    1,   1,   0,   0    }
    0,   0,   0,   0    }
int ledMillis2[7][4] = {
    1000,    0,   0,   0    }
    500,    0,   0,   0    }
    500,    0,   0,   0    }
    500,    0,   0,   0    }
    500,    0,   0,   0    }
    1000,    0,   0,   0    }
byte numSequences = 7;
byte numLeds = 4;
int ledSequenceNum = 0; // this is used in two functions
boolean ledSequenceDone = false;
int maxSeq = 2;
int sequence = 1;
//Here we handle the Globals of the button
int buttonState;             // the current reading from the input pin
int lastButtonState = LOW;   // the previous reading from the input pin
// the following variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long lastDebounceTime = 0;  // the last time the output pin was toggled
long debounceDelay = 50;    // the debounce time; increase if the output flickers
const int buttonPin = 2;    // the number of the pushbutton pin
  Serial.println("Starting LedSequence.ino");
  for(byte n = 0; n < numLeds; n++){
    pinMode(ledPins[n], OUTPUT);
  readSwitchesAndSaveValues();
  selectSequence();
  implementSequence();
  // only toggle the LED if the new button state is HIGH
  if (buttonState == HIGH) {
    if(sequence == maxSeq)
      sequence = 1;
      sequence++;
    switch(sequence)
    case 1:
    light1();
      break;
    case 2:
      light2();
      break;
void selectSequence() {
  if (ledSequenceDone == true) {
    ledSequenceNum ++;
    if (ledSequenceNum >= numSequences) {
      ledSequenceNum = 0;
void implementSequence() {
  static byte ledNum;            // static variables hold their value
  static unsigned long lastLedOn;
  static unsigned long ledInterval;
  int ledLights;
  int ledTimes;
  unsigned long currentMillis = millis();
  if (currentMillis - lastLedOn >= ledInterval) {  // the usual time check
    lastLedOn += ledInterval;    // save the current time
    digitalWrite(ledPins[ledNum], ledLights[ledSequenceNum][ledNum]); // light an led
    ledNum ++; // move on to the next in the sequence
    if (ledNum >= 4) {
      ledNum = 0;
      ledSequenceDone = true;
    ledInterval = ledTimes[ledSequenceNum][ledNum];
void readSwitchesAndSaveValues(){
  // read the state of the switch into a local variable:
  int reading = digitalRead(buttonPin);
  // check to see if you just pressed the button
  // (i.e. the input went from LOW to HIGH),  and you've waited
  // long enough since the last press to ignore any noise:
  // If the switch changed, due to noise or pressing:
  if (reading != lastButtonState) {
    // reset the debouncing timer
    lastDebounceTime = millis();
  if ((millis() - lastDebounceTime) > debounceDelay) {
    // whatever the reading is at, it's been there for longer
    // than the debounce delay, so take it as the actual current state:
    // if the button state has changed:
    if (reading != buttonState) {
      buttonState = reading;
    // save the reading.  Next time through the loop,
    // it'll be the lastButtonState:
    lastButtonState = reading;
