Hello. I have made a high powered LED switching circuit that is around 30 volts and powered by an Arduino. Running from some high discharge LIPO's and a 6 watt resistor. When I switch the LED on with a blink circuit, there's only 1 amp when there should be 3 ish. Could this be because the transistor is not being saturated or something by the Arduino? I am not really sure why this is happening to be honest. Any help would be appreciated. Thank you.
I have problems with word problems, post a schematic, of your system not a frizzy pictures. Post links to technical info on the hardware devices and be sure all the connections are on the schematic especially grounds.
An NPN power transistor designed way back in the 1960's, with a maximum current gain of 100 (closer to 35 at 3 amps collector current), is a very poor choice. A modern mosfet designed to be driven by a digital signal would be much, much better, as well as tremendously more efficient.
