Hi guys,
I have a question on combining two of my projects.
Goal: I'm aiming to send a "H" command out of my python project to pull in a contactor in a switch room using LoRa and an "L" command to de energize the contactor.
Currently I can send a H and an L to switch a relay on and off in one module connected directly to a COM port on the PC. (Project Serial_on_off.ino) and it works.
In a different project I have two arduino Uno's talking using a shield and I can short pins to turn relays on and off.
I'm stuck trying to combine the two. I would dearly love to send the "H" and "L" out of my python project through (LoRa_Remote_TX.ino) and receive it in the switchroom on the second Arduino (LoRa_Remote_RX.ino)
Ideally I'd love the receiving relay/s to momentarily hold on for long enough to energize the coil in my contactor before dropping out, but I'll take any help.
I'm quite new to Arduino and in the past have used ladder logic and PLC's for this type of thing. Possibly out of my depth here!
I really appreciate your time looking at my project.
Kind Regards,
Pat McMahon
PROJECT SERIAL_ON_OFF:
#define LED 13
const int relayPin = 2;
// Using http://slides.justen.eng.br/python-e-arduino as refference
pinMode(relayPin, OUTPUT);
if (Serial.available()) {
char serialListener = Serial.read();
if (serialListener == 'H') {
digitalWrite(relayPin, HIGH);
else if (serialListener == 'L') {
digitalWrite(relayPin, LOW);
LORA_Remote_TX.ino
int buttons[]={A0,A1,A2,A3}; //button pins
int leds[]={7,6,5,4}; //LED pins- bicolour
int outstates[]={0,0,0,0}; //initial output state
int instates[]={-1,-1,-1,-1}; //initial input state (invalid)
int lastbutton[]={1,1,1,1}; //last button state
#define LORAFREQ (915000000L)
#include <SPI.h>
#include <LoRa.h>
unsigned long tmout;
for(int i=0;i<4;i++){
pinMode(buttons[i],INPUT_PULLUP); //buttons short to ground when pressed
pinMode(leds[i],OUTPUT); //on
digitalWrite(leds[i],LOW); //red
LoRa.begin(LORAFREQ);
LoRa.onReceive(onReceive);
LoRa.receive();
tmout=millis();
int d=digitalRead(buttons[i]);
if((d==0)&&(lastbutton[i])){ //button pressed
delay(5); //basic debounce
if(digitalRead(buttons[i])==0){ //stable
outstates[i]=1-outstates[i]; //toggle
sendpacket(i);
lastbutton[i]=d;
digitalWrite(leds[i],outstates[i]); //change LED
if((instates[i]!=outstates[i])&&(((millis()/100)%2)==0)){pinMode(leds[i],INPUT);} //flash LED off if invalid feedback
if(millis()-tmout>10000){ //send every 10 seconds anyway
sendpacket(i);
delay(50); //space out transmissions
tmout=millis();
void sendpacket(int i){ //send current state of i
LoRa.beginPacket();
LoRa.print("BUTTON");
LoRa.print(i+1);
if(outstates[i]){
LoRa.print("ON");
}else{
LoRa.print("OFF");
LoRa.endPacket();
LoRa.receive();
void onReceive(int packetSize) {
char buf[20]="";
int k;
int n;
for (int i = 0; i < packetSize; i++) {
k=i;
if(k>18){k=18;} //make sure we don't write past end of string
buf[k]=(char)LoRa.read();
if(buf[0]!='R'){return;} //jump out if wrong data
if(buf[1]!='E'){return;} //jump out if wrong data
if(buf[2]!='L'){return;} //jump out if wrong data
if(buf[3]!='A'){return;} //jump out if wrong data
if(buf[4]!='Y'){return;} //jump out if wrong data
if(buf[5]!='S'){return;} //jump out if wrong data
if(buf[7]!='O'){return;} //jump out if wrong data
n=buf[6]-'1';
if((n<0)||(n>3)){return;} //invalid number
if((buf[8]=='F')&&(buf[9]=='F')){instates[n]=0;} //off received
if((buf[8]=='N')){instates[n]=1;} //on received
LORA_REMOTE_RX.ino
int relays[]={A0,A1,A2,A3}; //button pins
#include <SPI.h>
#include <LoRa.h>
pinMode(relays[i],OUTPUT); //output
digitalWrite(relays[i],LOW); //off
LoRa.receive();
tmout=millis();
if(millis()-tmout>9000){ //send every 10 seconds anyway
sendpacket(i);
delay(5); //space out transmissions
tmout=millis();
char buf[20]="";
int k;
int n;
k=i;
if(buf[0]!='B'){return;} //jump out if wrong data
if(buf[1]!='U'){return;} //jump out if wrong data
if(buf[2]!='T'){return;} //jump out if wrong data
if(buf[3]!='T'){return;} //jump out if wrong data
if(buf[4]!='O'){return;} //jump out if wrong data
if(buf[5]!='N'){return;} //jump out if wrong data
n=buf[6]-'1';
if((buf[8]=='F')&&(buf[9]=='F')){outstates[n]=0;} //off received
if((buf[8]=='N')){outstates[n]=1;} //on received
digitalWrite(relays[n],outstates[n]);
sendpacket(n);
LoRa.beginPacket();
LoRa.print("RELAYS");
LoRa.print(i+1);
if(outstates[i]){
LoRa.print("ON");
}else{
LoRa.print("OFF");
LoRa.endPacket();
LoRa.receive();
