Switching from Uno to Mega 2560 with no success!!
Hello!
I have an IDE code, that includes a couple of ultrasound sensors and the PCM library. When i put my hand closer to the ultrasound sensors, it plays a word i recorded at a higher frequency, as the hand gets closer.
It works perfectly on the Uno.
Now i want to put in several more ultrasound sensors, but don't have enough pin input places on the Uno.
So, i checked out again that the code works perfectly on the Uno and first of all i tried to switch to the exact pin numbers, ground connections and 5V connections, on the Mega, without adding any new ultrasound sensors. But, nothing happens - the speaker is totally silent! i checked and rechecked if i switched all the wires to the exact same places and yet all is the same, but the speaker is not working, then i switched back to the Uno again - and it is working! Back again to the Mega - Not working!!
What should i do?
What might be the reason?
Thanks a lot!!
Post your code. Likely related to which pins support PWM.
Hello CrossRoads!
Thanks for replying!
Please take into account, that i am only a beginner hobbyist, taking patches of code from here and there and putting them together, with no real in-depth understanding…
Here is the code:
(code tags added by moderator for beginner hobbyist)
#include <PCM.h>
#include <SoftwareSerial.h>
SoftwareSerial mySerial(3, 4); // RX, TX
int isObstacle=0;
int ObstacleLoop=0;
int leftObstacleLoop1=0;
int leftObstacleLoop2=0;
int leftObstacleLoop3=0;
int rightObstacleLoop1=0;
int rightObstacleLoop2=0;
int rightObstacleLoop3=0;
int winFlag=0;
//const unsigned char sample[] PROGMEM = {
//  126, 127, 128, 128, 128,  127,  //Took out all the mass of numbers
const unsigned char sample_left[] PROGMEM = {
129, 128, 128, 127, 128, 127, 127, 128,  //Took out all the mass of numbers
const unsigned char sample_right[] PROGMEM = {
126, 127, 127, 126, 127,  128, 128,  //Took out all the mass of numbers
const unsigned char silence[] PROGMEM = {
  126, 127, 127, 126, 127, //Took out all the mass of numbers
#define trigPin 6
#define echoPin 7
#define trigPin1 12
#define echoPin1 13
   mySerial.begin(9600);
  Serial.begin (9600);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  pinMode(trigPin1, OUTPUT);
  pinMode(echoPin1, INPUT);
   //mySerial.println("XXX?");
     long duration, distance, duration1, distance1;
   digitalWrite(trigPin, LOW);  // Added this line
   delayMicroseconds(4); // Added this line
   digitalWrite(trigPin, HIGH);
   delayMicroseconds(10); // Added this line
   duration = pulseIn(echoPin, HIGH);
   distance = (duration/2) / 29.1;
  digitalWrite(trigPin1, LOW);  // Added this line
  digitalWrite(trigPin1, HIGH);
  duration1 = pulseIn(echoPin1, HIGH);
  distance1 = (duration1/2) / 29.1;
  if(winFlag==0 && isObstacle==0){
    mySerial.write(byte(0));
      // winFlag=1;
 if (distance <= 200 && distance < distance1){
     startPlayback(sample_left, sizeof(sample_left));
     winFlag=1;
     if (distance <=200 && distance >=50) {
     isObstacle=0;
      if(ObstacleLoop==0){
      winFlag=1;}
    ObstacleLoop=1;
    startPlayback(silence, sizeof(silence));
    delay(250);
    else  if (distance <=50 && distance >=28) {
     isObstacle=0;
      winFlag=1;}
    ObstacleLoop=1;
    delay(250);
 else if (distance <=28 && distance >=24) {
     isObstacle=0;
      winFlag=1;}
    ObstacleLoop=1;
      delay(2440);
       else if (distance <=24 && distance >=20){
     isObstacle=0;
      winFlag=0;}
      ObstacleLoop=1;
       delay(1500);
        else if (distance <=20 && distance >=16){
       isObstacle=0;
        winFlag=0;}
        ObstacleLoop=1;
        delay(1080);
         else if (distance <=16 && distance >=12){
         isObstacle=0;
        winFlag=0;}
          ObstacleLoop=1;
        delay(740);
          else if (distance <=12 && distance >=8){
             if(leftObstacleLoop3==0)
             mySerial.write(byte(1));
             isObstacle=1;
             ObstacleLoop=0;
              leftObstacleLoop3++;
              winFlag=0;
          delay(530);
           else if (distance <=8 && distance >=4){
            if(leftObstacleLoop2==0)
             isObstacle=1;
              ObstacleLoop=0;
              leftObstacleLoop2++;
               winFlag=0;
           delay(340);
           else if (distance <=4 && distance >=0){
             if(leftObstacleLoop1==0)
             isObstacle=1;
              ObstacleLoop=0;
              leftObstacleLoop1++;
               winFlag=0;
              delay(180);
            else {
             isObstacle=0;
             if(ObstacleLoop==0)
              ObstacleLoop=1;
  else  startPlayback(silence, sizeof(silence));
  if (distance1 <= 200 && distance1 < distance){
     startPlayback(sample_right, sizeof(sample_right));
     winFlag=1;
           if (distance1 <=200 && distance1 >=50) {
     isObstacle=0;
      winFlag=0;}
      ObstacleLoop=1;
      delay(250);
     else if (distance1 <=50 && distance1 >=28) {
     isObstacle=0;
      winFlag=0;}
      ObstacleLoop=1;
      delay(250);
    else if (distance1 <=28 && distance1 >=24) {
     isObstacle=0;
      winFlag=0;}
      ObstacleLoop=1;
      delay(2440);
       else if (distance1 <=24 && distance1 >=20){
       isObstacle=0;
        winFlag=0;}
        ObstacleLoop=1;
       delay(1500);
        else if (distance1 <=20 && distance1 >=16){
       isObstacle=0;
        winFlag=0;}
        ObstacleLoop=1;
        delay(1080);
         else if (distance1 <=16 && distance1 >=12){
       isObstacle=0;
        winFlag=0;}
        ObstacleLoop=1;
        delay(740);
          else if (distance1 <=12 && distance1 >=8){
             if(rightObstacleLoop3==0)
             mySerial.write(byte(2));
             isObstacle=1;
              ObstacleLoop=0;
              rightObstacleLoop3++;
               winFlag=0;
          delay(530);
                else if (distance1 <=8 && distance1 >=4){
                 if(rightObstacleLoop2==0)
                  isObstacle=1;
                  ObstacleLoop=0;
                  rightObstacleLoop2++;
                   winFlag=0;
                  delay(340);
           else if (distance1 <=4 && distance1 >=0){
             if(rightObstacleLoop1==0)
             isObstacle=1;
              ObstacleLoop=1;
              rightObstacleLoop1++;
               winFlag=0;
              delay(180);
            else {
               isObstacle=0;
            if(ObstacleLoop==0)
            ObstacleLoop=1;
