Dear all,
I am trying to build string monitoring solution for solar application. There are totally 24 string carrying 25A @ 1000v. commonly connected via string to bus bar. Main purpose of string monitor is to measure current through each string. It not need to measure current for every XX min of interval. Purpose is to make ensure all string are providing proper current
I have done with 2 ways
- hall sensor based current transducer : where each string pass through hall sensor. which gives analog output 0~5v .
- Shunt basis method: I have attached similar link above. Where current measured w.r.t RSh and gives 0~5v analog output connected to sensor.
I used MUX circuit after each analog output and connected to arduino uno board.
Both are working fine Now. Based on this i am trying to do similar since all connected common bus bar before giving input Rshunt resistor is it possible to switch the input level. like in MUX. I know we can't do with IC @ that voltage. Instead of making seprate 24 string/using indivual hall or shunt basis network. Can We use one circuit and just switch the input and read the string .
Is it SAFE???
Is there any way of doing it.
This will reduce my cost.
