Hello,
What I am expecting and hoping for, is that a potentiometer (with Arduino codiing) is used to trigger (using if statement) a motor driver only for a certain duration (using a for-loop) for one iteration only (the motor would stop at the end of the for-loop). When the potentiometer is moved back the other way the motor driver would hypothetically go back the same amount of time to the starting position.
Is this at all possible? I also get an error with my code saying a function-definition is not allowed here before ‘{’ token right at the beginning of void loop () {
// MOTORSHIELD OUTPUT PINS (TWO ARE PWM):
int enA = 9; // Motorshield / Motordriver pin enA to Arduino PWM pin 10,
int in1 = 2; // Motorshield / Motordriver pin in1 to Arduino PWM pin 9
int in2 = 4; // Motorshield / Motordriver pin in2 to Arduino pin 8
// Far ends of potentiometer are connected to GND, and another to either 3.3V or 5V terminals on Arduino.
// Middle potentiometer pin is connected to A0 (above code)
// Second potentiometer middle pin is connected to A5
int drive_pote_pin = A0;
int drive_pote_value;
// Set pins as output:
pinMode(enA, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
int x = 1;
int y = 1;
int drive_pote_value = analogRead(drive_pote_pin); // Read the feedback mechanism (or whatever mechanism)
if (drive_pote_value < 512)
for (int i = 0; i <= 255; i++)
digitalWrite(in1, HIGH);
digitalWrite(in2, LOW);
analogWrite(enA, 255);
delay(10);
if (drive_pote_value > 512)
for (int j = 0; j <= 255; j++)
digitalWrite(in1, LOW);
digitalWrite(in2, HIGH);
delay(10);
