Hi to all
i have one sim800L module that i want to switch on/off the power from an arduino (Pro mini 3.3v - 8MHz) .
the sim800L needs 3.4v - 4.4 volt dc
i am using a 18650 battery back that delivers 3.7 volt
when i am connecting the battery directly to the module , works fine
i tried to use simple npn transistors (NPN 3904, 2N2222, bc547c) and a darlington transistor (tip120) but was not able to make the module work .
i have a drop of voltage about 0.5v (3.2 volt on the module through the npn) so the module cant connect to the cellular network (very common problem when it has not enough power)
are any other solutions to suggest me in order to open and close the power of this module through the arduino ?
Thanks in advance
