I am trying to get mutiple inputs using Arduino Uno and Several 74HC4067 Chips. I'm using Four Digital Pins to Address each of the inputs on the Chip. However, the Switching seems to be not working according to plan. This is my Code...(When I measure the voltage across Digital Pin 1, I do not see it fluctuating, and only give 5V - note I have given adequate delay, 3sec to measure...)
Any help is much appreciated
int PinSelect0 =0;
int PinSelect1 =1;
int PinSelect2 =2;
int PinSelect3 =3;
digitalWrite(PinSelect0, HIGH);
digitalWrite(PinSelect1, LOW);
digitalWrite(PinSelect2, LOW);
digitalWrite(PinSelect3, LOW);
SensorValue = digitalRead(4); // read the arduino input pin the Chip is using
Serial.print(SensorValue); //use the result
delay(3000);
digitalWrite(PinSelect1, HIGH);
SensorValue1 = digitalRead(4); // read the arduino input pin the Chip is using
Serial.print(SensorValue1); //use the result
delay(3000);
// break;
Why are you expecting digital pin 1 to change?
The 74HC4067; 74HCT4067 is a 16-channel analog multiplexer/demultiplexer with four
address inputs (S0 to S3), an active-LOW enable input (E), sixteen independent
inputs/outputs (Y0 to Y15) and a common input/output (Z).
How do you have the chip(s) connected to the Arduino?
I am expecting Digital Pin2 to change as I have two set of selection statements in my code. Within the loop the first addressing is to select Output 1 of the IC - Y1(Address 0001), and next is to read output 3 of the IC - Y3 (address 0011 in Binary addressing) so Digital Pin 1 (2nd Lowermost Bit) should change between 0 to 1 within the loop. (I have added a delay to ensure that the state does not change too fast to measure) - So ideally the voltage should change between 5V and something much less to logic 0.
I have the Chips connected, but even without connecting them, I do not see the variance when I measure DigitalPin2 Voltage from Arduino..
Thank you very much for your assitance in advance :)
Thanks I will re do without using Pin0 & 1. But I did try similarly to use the Analog Pins 0 -3 to address mux inputs, with same results...anyway My MUX is connected to 16 PhotoTransistors - but in this test case I just plug the test inputs to +5V (Vcc)
You may want to first experiment with the multiplex chip independent of the arduino. Use a multimeter across the input/common output of the chip, power the chip with 5v, and experiment with the control pins either connected to 5v or ground. If the control pins float when not set to 5v, you may not get what you expect.
Hi Everyone. Thank You for the Valuable Information ( Grumpy_Mike, zoomkat, PaulS). I have re-done the wiring using pins 2-5 for Switching and 6-9 for Data Input from Multiplexer Chips. It works fine now.
