Hello I am looking for advice on using an Arduino to turn a small AC load on and off. The load is a cannabilized LED array inside of an LED bulb that's made to screw into an Edison socket; essentially all of the "guts" of a standard LED bulb.
I already have and know that I could most easily use a relay shield, but it makes a loud clack when energizing/de-energizing that I want to avoid. Thanks for the recommendations.........
So I guess I didn't post an actual question which is: how do I best/most easily switch an AC circuit that just feeds a single Edison socket LED bulb using an Uno/Nano? I want to avoid using a SEEEDUINO relay shield (not that I have ANYTHING against the company or the device) that I already possess just because I don't want the noise of the relays energizing/de-energizing.
It never ceases to amaze me how much has changed in the last 20 years or so in electronics......
I am coming to realize that it is far better to check to see if there isn't an already-made device than to start from scratch with the idea of making everything myself......
