Hello, i have a project with 4 relay and 4 buttons , 3 relays and buttons can turn on and off and 1 will be using RTC Module to automatic turn on and off relay with a schedule time every day.
i want to use the 1 button to switch to manual and auto mode. HIGH or LOW value
for example:
initial state of the auto/manual button will be HIGH
if i push the auto/manual button the code for schedule time to turn and off the relay
if i push the again auto/manual button it will go back to the manual button to turn on and off the relays
I already have the code from the internet but when I'm pressing the auto/button the code execute the schedule time to turn on and off but when I release the button it will execute the manual button control.
is there a way that when i press it will only execute the first code and when press again execute the second code.
thanks
#include <virtuabotixRTC.h>
virtuabotixRTC myRTC(6, 7, 8);
const int OnHour = 10; //SET TIME TO ON RELAY (24 HOUR FORMAT)
const int OnMin = 45;
const int OffHour = 10; //SET TIME TO OFF RELAY
const int OffMin = 47;
const int waitTime = 60000;
const int BUTTON_PIN = 12; // Auto/Manual Button
const int RELAY_PIN = 2; // relay when press auto/manual button light indicator will turn on
// variables will change:
int relayState = LOW; // the current state of relay
int lastButtonState; // the previous state of button
int currentButtonState; // the current state of button
const int pushButton[] ={9,10,11};// define push button inputs
const int relayPin[]={3,4,5};// output pins where 4 relays will be connected
String relayNames[] ={"CH1","CH2","CH3"};// Just put name for 4 relays
int pushed[] ={0,0,0};// status of each buttons
int relayStatus[] ={HIGH,HIGH,HIGH};// initial status of relay
// Robojax.com 4-Relay-4-Push button 20181211
Serial.begin(9600);// initialize serial monitor
// SET TIME AND DATE
myRTC.setDS1302Time(55, 44, 10, 3, 30, 11, 2022);
pinMode(BUTTON_PIN, INPUT_PULLUP); // set arduino pin to input pull-up mode
pinMode(RELAY_PIN, OUTPUT); // set arduino pin to output mode
digitalWrite(RELAY_PIN, HIGH); // set relay initial to high
for(int i=0; i<3; i++)
pinMode(pushButton[i], INPUT_PULLUP);
pinMode(relayPin[i], OUTPUT);
digitalWrite(relayPin[i], HIGH);// initial relay status to be OFF
myRTC.updateTime();
// Start printing elements as individuals
Serial.print("Current Date / Time: ");
Serial.print(myRTC.dayofmonth);
Serial.print("/");
Serial.print(myRTC.month);
Serial.print("/");
Serial.print(myRTC.year);
Serial.print(" ");
Serial.print(myRTC.hours);
Serial.print(":");
Serial.print(myRTC.minutes);
Serial.print(":");
Serial.println(myRTC.seconds);
// Delay so the program doesn't print non-stop
delay(50);
lastButtonState = currentButtonState; // save the last state
currentButtonState = digitalRead(BUTTON_PIN); // read new state
if(currentButtonState == HIGH){ // manual button control
int val = digitalRead(pushButton[i]);
if(val == HIGH && relayStatus[i] == LOW){
pushed[i] = 1-pushed[i];
delay(100);
}// if
relayStatus[i] = val;
if(pushed[i] == HIGH){
Serial.print(relayNames[i]);
Serial.println(" ON");
//Serial.println(pushed[i]);
digitalWrite(relayPin[i], LOW);
else{
Serial.println(" OFF");
}//FOR
}// if
if(currentButtonState == LOW) { //auto control
// SCHEDULE TIME TURN ON AND OFF
if (myRTC.hours == OnHour && myRTC.minutes == OnMin && relayStatus[0] == HIGH){
digitalWrite(relayPin[0], LOW);
Serial.println("LIGHT ON");
else if(myRTC.hours == OffHour && myRTC.minutes == OffMin && relayStatus[0] == LOW){
digitalWrite(relayPin[0], HIGH);
Serial.println("LIGHT OFF");
Serial.println("==========================================");
delay(100);
}// loop end
