switching tube lights
hey,
Noob question here: : I’m trying to switch 8 tubelights (blacklight TL) on and of using arduino.
I would need some kind of relais since the lights are working on 220 volts.
How do i do this? Any tips?
Easiest way to do something like this is with a solid state relay. It will take the output from the Arduino directly, and you will be able to control the current running to the lights.
Otherwise, you will need a transistor of some sort, and a relay.
i found this thing:
http://be02.rs-online.com/web/search/searchBrowseAction.html?method=searchProducts&searchTerm=683-8722&x=0&y=0
which would work with 5v - 220v, but i read in the arduino diecimilla spec: DC Current per I/O Pin: 40 mA
will this work?
thnx
The relay coil takes just over 100mA so you need a transistor to drive the relay. Look at:-
http://www.thebox.myzen.co.uk/Workshop/Motors_1.html
