SWOD: SweepWithOutDelay
Thought I'd share this delay()-less millis()-based servo sweep code.
Two independent servos are swept between setable limits, with setable degrees/increment, with setable ms between increment.
Includes #define for debugging.
All the user setable values are between 2 lines of code:
/////////   set the values below
/////////   set the values above
Rather grab newer code from Reply #1, very slight changes.
Slight changes on UKHeliBob’s suggestion. (Made the checking for the servos being at the limits into inequqlities.)
// Delay()-less millis()-based sweep for 2 servos, X and Y
// This example code is in the public domain.
// manor_royal Feb 2017
//idea is for two servos to go up and down ala sweep
//   BUT to interleave their motion
// in this one the servos can have diff ranges and speeds
// both of which hardcoded
//basically bwod thinking... "SWOD": SweepWithOutDelay
#include <Servo.h>
Servo servoX;
Servo servoY;
byte posX;
byte posY;
// x range degrees
byte posXmin = 10;
byte posXmax = 170;
// y range degrees
byte posYmin = 50;
byte posYmax = 100;
//degrees per move.. gets *-1 immed for +1 first time
int stepX = -1;
int stepY = -1;
//millisec per update, larger is slower
int speedX = 25;
int speedY = 250;
//servo pins
byte servoXpin = 2;
byte servoYpin = 3;
/////////// set the values above
unsigned long currentMillis = 0;
unsigned long previousMillisX = 0; // the time when the servo was last moved
unsigned long previousMillisY = 0;
//  (un)-comment the following
//#define DEBUG //serial prints
#define DEBUG1 //led13
#define LCD_PRESENT_BUT_NOT_USED
  posX = posXmin;
  posY = posYmin;
  servoX.write(posX);  //initialise
  servoY.write(posY);
  servoX.attach(servoXpin);
  servoY.attach(servoYpin);
#ifdef DEBUG
  Serial.println("setup " + String(posX) + " " + String(posY));
#endif
#ifdef DEBUG1
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, HIGH);
  digitalWrite(LED_BUILTIN, LOW);
#endif
#ifdef LCD_PRESENT_BUT_NOT_USED
  pinMode(10, OUTPUT); //turn backlight off
#endif
  currentMillis = millis();
  moveX();
  moveY();
#ifdef DEBUG
  delay(100);
#endif
}//loop
void moveX()
  if (currentMillis - previousMillisX >= speedX) //move if X time elapsed else nothing
    previousMillisX = currentMillis;
    if ((posX <= posXmin) || (posX >= posXmax))
      stepX = -1 * stepX; //change direction at limits
    servoX.write(posX);
    posX = posX + stepX;
#ifdef DEBUG
    Serial.print("moveX " + String(posX) + " " + String(stepX));
#endif
  }//millis if
} //moveX
void moveY()
  if (currentMillis - previousMillisY >= speedY) //move if Y time elapsed else nothing
    previousMillisY = currentMillis;
    if ((posY <= posYmin) || (posY >= posYmax))
      stepY = -1 * stepY; //change direction at limits
    servoY.write(posY);
    posY = posY + stepY;
#ifdef DEBUG
    Serial.println("  moveY " + String(posY) + " " + String(stepY));
#endif
  }//timing
}//moveY
