Swtich/case statments: No luck!
Hey!
I can't get any swtich/case statements working.
Here's mine:
swtich (switchState)
case 0:
      if (menuItem == 1)
      {menuItem= 5;}
      {menuItem--;}
case 1:
      (if menuItem == 5)
      {menuItem=0;}
      {menuItem++;}
case 3:
      menuItem=6:
all the variables are ints, and are defined ect. I get the error:
error: 'swtich' was not declared in this scope
So, i copied and pasted the example from Arduino.cc:
 int var = 1;
  switch (var) {
    case 1:
      //do something when var == 1
      // break is optional
    case 2:
      //do something when var == 2
    default:
      // if nothing else matches, do the default
      // default is optional
and i get the error:
error: expected unqualified-id before 'switch'
What the devil am i doing wrong?
Cheers!
Nick D
Hi Nick
You typed swtich when you intended switch
And the example code is missing an expression in the default statement.
Add a semicolon after default: (or remove the default statement) and it should compile
Good luck!
Dyslexia strikes again!
