SX1276 library
Hi everybody,
I have implemented an application based on using a LoRa shield, SX1276MB1MAS with Arduino101 and have been using the sx1272 library which I see is not including all the existing options available on SX1276.
I am looking for the best library for the node-to-node RX/TX. There are different libraries available for SX1276. Do you know the best one?
Thanks in advance for any help!
mebab:
Which SX1272 library have you been using ?
It was an older version of the following link. For example, neither older nor newer include Continuous operation mode of RX. They just have Single operation mode of RX:
https://os.mbed.com/teams/BTSSN-Projet-Drone-Imagerie-et-Telemetri/code/SX1272/
mebab:
SX1272 - Library SX1272, initially created by C.Pham, Univ… | Mbed
Ah, so a library called a SX1272 library that is also a SX1276 library.
No idea what you mean by;
"Continuous operation mode of RX. They just have Single operation mode of RX"
Can you explain ?
Please look at page 40 and 41 in the following address:
It is about two modes of packet reception.
I think you will have to check the various libraries to see whether the are using the 'Continuous ' mode. I dont recall a library mentioning you could flip between the two.
