So you got me wondering if I just got lucky with my RF remote control then:
I am using pin 10 as Slave Select with SPI to a MAX7221, I only made these statements for the receiver:
// Initialise the Wireless Receiver IO and ISR
// set Virtual Wire data input to Pin 9 from 11
vw_set_rx_pin(9); // found this in forum 25 Aug 09
// set the Bits per sec
vw_setup(2000);
// Start the receive PLL running
vw_rx_start();
and only this for the transmitter, with D10 being used as a Column pin for a keypad, and D11/D13 not used.
// Initialise the IO and ISR for VirtualWire
vw_setup(4000); // Bits per sec - had to double from 2000 with 8MHz 3.3V Pro-Mini
"I am shifting the ptt pin to 15,which is undefined for uno."
15 is not undefined - it is the same as A1 (A0-A5 = D14-D19).
If you want undefined, I would go for >=20.
Hey myfaithnka can you post your fixed transmitter and receiver code after you fixed your synchronization problem. I am trying to send integer values from two sensors and I am having the same problem you had with the mixed up values, but I can't figure out what is wrong. Thanks in advance.
