Hi Everyone,
I need to transmit a synchronization pulse on Serial1 and Serial2 of Arduino Due. I have had no issues in the past when I used the following code in a library I created, however right now, it is not functioning.
(Here I include all the code in one spot)
unsigned long t1,t2;
Serial1.begin(9600);
Serial2.begin(9600);
t1 = millis();
t2 = t1;
t1 = millis();
if(((t1-t2) >= 500) || (t2>t1))
TxSyncBreakDue(1,104);
Serial1.write(0x12);
Serial1.write(0x23);
t2 = t1;
int TxSyncBreakDue(int SerCh,unsigned long Period_us)
unsigned int del = Period_us * 13; // delay for number of bits in microseconds, depends on period
if(SerCh == 2)
PIOA->PIO_PER = PIO_PA13; // enable PIO register
PIOA->PIO_OER = PIO_PA13; // enable PA13 as output
PIOA->PIO_CODR = PIO_PA13; // clear PA13
delayMicroseconds(del); // delay
PIOA->PIO_SODR = PIO_PA13; // set pin high
delayMicroseconds(Period_us);
PIOA->PIO_PDR = PIO_PA13; // clear configuration for PIO, needs to be done because Serial wont work with it
else if(SerCh == 1)
PIOA->PIO_PER = PIO_PA11; // enable PIO register
PIOA->PIO_OER = PIO_PA11; // enable PA11 as output
PIOA->PIO_CODR = PIO_PA11; // clear PA11
PIOA->PIO_SODR = PIO_PA11; // set pin high
PIOA->PIO_PDR = PIO_PA11; // clear configuration for PIO, needs to be done because Serial wont work with it
return -1;
return SerCh;
Does anyone have any idea what settings I may have accidentally changed that would cause this?
I search the Due files in C:users\xxxxxxx\Arduino15\packages\arduino\hardware for any files that were modified in the past few days, and it nothing appears to have been modified.
Yesterday, I tried viewing some of the Timer-Counter registers, however I highly doubt that a mere read of the registers would set some setting preventing me from transmitting my Sync Pulse.
Thanks!
