I've spent so much time trying to upload some code to my Mini Pro and all I get are three flashing lights on the Rx before the "avrdude: stk500_getsync(): not in sync: resp-0x00"
I bought three mini Pros and have the usb2 serial adapter. The first PCB I soldered had the transistors backwards thanks to some mis-labeling. The second PCB I soldered went in beautifully, and now I'm trying to upload the code to it. The Arduino USB2serial either says that the COM port is already taken, in which case I have to unplug and plug in the usb and then reboot. Other with I get that sync error.
I've tried pressing the button on the mini pro when the three flashes happens, no luck.
I've tried burning the bootloader: This report would have more information with
enabled in File > Preferences.
Arduino: 1.0.6 (Windows 7), Board: "Arduino Pro or Pro Mini (5V, 16 MHz) w/ ATmega328"
avrdude: usbdev_open(): did not find any USB device "usb"
I've spent hours looking for a solution and I'm just about to give up on this project.
I'm using a really good soldering iron (Hakko). Could it be that the mini pro is burned out? There was no issue and there's nothing that looks burned (the mini pro power light comes on). Mayeb there's a special temperature?
I'm out of ideas. I need help!
