Hello,
I used “From Arduino to Microcontroller in a Breadboard” tutorial last year and it worked fine.
Now I have a new project, with the same breadboard and components, and I am getting
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x3f
I use Arduino Uno R3 (two boards) as programmer
Ide is 1.8.13
I tested all solutions in this forum with no chance.
- To feed from an external source,
- To install two more capacitors in VCC & and 20,
- To test micros programmed in other boards, that r5.un OK in the breadboard
- To play with reset line as suggested,
- To test two different micros that run Ok in their R3 boards
I will paste the error lines that I get:
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM9 -b115200 -D -Uflash:w:C:\Users\HBB\AppData\Local\Temp\arduino_build_100531/Blink3.ino.hex:iavrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg WunschSystem wide configuration file is “C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf”
Using Port : COM9
Using Programmer : arduino
Overriding Baud Rate : 115200avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x3f
Thank you !
Horacio
stk500_getsync
