This question relates to the use of TimeLib.h
Basically, I want to sync my time with the NTP server and set it as the default system time and then break whatever value is into variables that I can use in loops. I tried doing this with a few methods.
void printLocalTime(){
struct tm timeinfo;
if(!getLocalTime(&timeinfo)){
Serial.println("Failed to obtain time");
return;
and then
int tday = (*timeinfo, "%d") did not work.
int tday = timeinfo.tm_mday did not work
int tday = day() did not work
I tried using the default esp8266 example that comes with the library but that doesn't work with my esp32.
Juraj
July 15, 2021, 8:56am
2
this example of unrelated library has it
#include <WiFi.h>
#include <TimeLib.h>
#include <TelnetStream.h>
const long gmtOffset_sec = 3600;
const int daylightOffset_sec = 3600;
#include "arduino_secrets.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
const char ssid[] = SECRET_SSID; // your network SSID (name)
const char pass[] = SECRET_PASS; // your network password (use for WPA, or use as key for WEP)
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(ssid);
WiFi.begin(ssid, pass);
if (WiFi.waitForConnectResult() != WL_CONNECTED) {
Serial.println("Failed to connect.");
This file has been truncated. show original
I am assuming you are pointing me towards the part of the code that
time_t now = time(nullptr);
while (now < SECS_YR_2000) {
delay(100);
setTime(now);
After adding this code I did
Serial.println("Day today is is");
Serial.print(day()); The output is "1" meaning that it still thinks its day one
Serial.print("Day of Month: ");
Serial.println(&timeinfo, "%d"); Works perfectly
Since day () does not produce a value I cant save it in a variable and I cant do
int todayis = (&timeinfo, "%d");
I have gone through both the documentation and the example you have given The documentation shows to solution to my specific problem.
and speaking of example, it also does not show any solution.
They are getting the values by doing
struct tm timeinfo;
and use
to get the day of the month. But how do i add it into a variable?
tm is a struct.
timeinfo your instance of the struct.
so you could use a
Serial.print(timeinfo.tm_mday); // day of month
to print or similar to assign to another variable. but what for? The value is available in the struct anyway.
here you find my working example of NTP for the ESP:
[url]https://werner.rothschopf.net/microcontroller/202103_arduino_esp32_ntp_en.htm[/url]
Thank you but I believe I am doing something very wrong but "Serial.print(timeinfo.tm_mday);" gave this error.
'struct tm' has no member named 'tm_day'
Basically, I am trying to create a loop that goes like this
if (day:month == day:montth+1){
do stuff }
else {
do other stuff }
so I need different parts of the time struct to perform this. I need to loop between a certain date that comes every month.
any chance that you just give the sketch from my page a try?
Does it compile?
Does it output the current time?
Thank you for this. Has solved my problem for now. Hopefully, I can learn from this.
system
Closed
November 13, 2021, 5:59am
10
