Hi I'm having a synch problem.
Arduino Code:
typedef struct JoystickEstadoAtual{
int movimento;
int btn1;
int btn2;
int btn3;
}JoystickEstadoAtual;
JoystickEstadoAtual joystickEstadoAtual;
joystickEstadoAtual.movimento = 1;
joystickEstadoAtual.btn1 = 2;
joystickEstadoAtual.btn2= 3;
joystickEstadoAtual.btn3 = 0;
Serial.write((const uint8_t *)&joystickEstadoAtual, sizeof(joystickEstadoAtual));
C code:
#include <Windows.h>
#include <stdio.h>
typedef struct JoystickEstadoAtual {
byte movimento;
byte btn1;
byte btn2;
byte btn3;
void openPort(HANDLE* hComm) {
char ComPortName[] = "\\\\.\\COM3";
*hComm = CreateFile(ComPortName, // Name of the Port to be Opened
GENERIC_READ | GENERIC_WRITE, // Read/Write Access
0, // No Sharing, ports cant be shared
NULL, // No Security
OPEN_EXISTING, // Open existing port only
0, // Non Overlapped I/O
NULL); // Null for Comm Devices
if (*hComm == INVALID_HANDLE_VALUE) {
printf("\n Error! - Port %s can't be opened\n", ComPortName);
system("exit");
else {
printf("\n Port %s Opened\n ", ComPortName);
BOOL settings(HANDLE hComm) {
BOOL Status = TRUE;
/*------------------------------- Setting the Parameters for the SerialPort ------------------------------*/
DCB dcbSerialParams = { 0 }; // Initializing DCB structure
dcbSerialParams.DCBlength = sizeof(dcbSerialParams);
Status = GetCommState(hComm, &dcbSerialParams); //retreives the current settings
if (Status == FALSE) {
printf("\n Error! in GetCommState()");
return Status;
dcbSerialParams.BaudRate = CBR_9600; // Setting BaudRate = 9600
dcbSerialParams.ByteSize = 8; // Setting ByteSize = 8
dcbSerialParams.StopBits = ONESTOPBIT; // Setting StopBits = 1
dcbSerialParams.Parity = NOPARITY; // Setting Parity = None
Status = SetCommState(hComm, &dcbSerialParams); //Configuring the port according to settings in DCB
printf("\n Error! in Setting DCB Structure");
return Status;
else //If Successfull display the contents of the DCB Structure
printf("\n\n Setting DCB Structure Successfull\n");
printf("\n Baudrate = %d", dcbSerialParams.BaudRate);
printf("\n ByteSize = %d", dcbSerialParams.ByteSize);
printf("\n StopBits = %d", dcbSerialParams.StopBits);
printf("\n Parity = %d", dcbSerialParams.Parity);
/*------------------------------------ Setting Timeouts --------------------------------------------------*/
COMMTIMEOUTS timeouts = { 0 };
timeouts.ReadIntervalTimeout = 50;
timeouts.ReadTotalTimeoutConstant = 50;
timeouts.ReadTotalTimeoutMultiplier = 10;
timeouts.WriteTotalTimeoutConstant = 50;
timeouts.WriteTotalTimeoutMultiplier = 10;
if (SetCommTimeouts(hComm, &timeouts) == FALSE) {
printf("\n\n Error! in Setting Time Outs");
return Status;
printf("\n\n Setting Serial Port Timeouts Successfull");
/*------------------------------------ Setting Receive Mask ----------------------------------------------*/
Status = SetCommMask(hComm, EV_RXCHAR); //Configure Windows to Monitor the serial device for Character Reception
printf("\n\n Error! in Setting CommMask");
return Status;
else {
printf("\n\n Setting CommMask successfull");
return TRUE;
void closePort(HANDLE hComm) {
CloseHandle(hComm);//Closing the Serial Port
void readPort(HANDLE hComm) {
BOOL Status;
DWORD NoBytesRead; // Bytes read by ReadFile()
DWORD dwEventMask; // Event mask to trigger
/*------------------------------------ Setting WaitComm() Event ----------------------------------------*/
Status = WaitCommEvent(hComm, &dwEventMask, NULL); //Wait for the character to be received*/
/*-------------------------- Program will Wait here till a Character is received ------------------------*/
else //If WaitCommEvent()==True Read the RXed data using ReadFile();
while (1) {
Status = ReadFile(hComm, &joystickEstadoAtual, sizeof(joystickEstadoAtual), &NoBytesRead, NULL);
printf("Movimento: %d\n", joystickEstadoAtual.movimento);
printf("BTN 1: %d\n", joystickEstadoAtual.btn1);
printf("BTN 2: %d\n", joystickEstadoAtual.btn2);
printf("BTN 3: %d\n", joystickEstadoAtual.btn3);
Sleep(1000);
void main(void)
HANDLE hComm; // Handle to the Serial port // Name of the Serial port(May Change) to be opened,
BOOL Status; // Status of the various operations
openPort(&hComm); // Open Port
Status = settings(hComm); //Set configuration Port
printf("ERRO!");
else {
readPort(hComm);
closePort(hComm);
system("exit");
}//End of Main()
Is there a way to get the right data? What I need to do is write the whole struct(it can be an array too, if it's possible) and the C program will read the right data.
Because what I got until now is for example, the arduino code is sending a 1, 2, 3, 0, and the c program is getting 2, 3, 0, 1 for example.
I think about another two solution: The first solution is to increase the buffer COM PORT, but how can I do this in arduino? The second solution is split a com port in two another ports, but how can I do this in arduino too?
I'm accepting another solutions too.
Thanks !
