Synchronisation with Twin Linear Emcodes
below are the available tools:
Arduino Mega 2560 Rev.3
I have 2 linear encoders.
2 hydraulic cylinders
2 selenoid proportional valves.
my question :
can these two hydraulic cylinders move the same and always synchronous?
if there is a special tool that can move two hydraulics always synchronous, tell me the name of the tool?
if the code must use PID, please teach me how?
Is there a sample code in Arduino to move the hydraulic cylinder synchronously?
I beg for your help, I really appreciate your suggestions and your work.
i love arduino
For Hydraulics it is usually just a "Y" adaptor in the feed and return to tank hydraulic lines to a matched pair of cylinders.
Usually as close to centre of the feed as possible.
If you want to also pressure the return use a CO shuttle valve with a return to tank port from the pressure lines.
Part of that answer also depends on the cylinder type double acting / single acting etc.
WestJava:
No links to datasheets? That's the first thing we need to understand any hardware question.
