After figuring out how to transmit data to the computer and read it with LabVIEW (here) I went ahead and built a function that will transmit all the wanted data (in this case- the values recieved from MPU9150, and results of the strapdown calculations):
void printResults()
Serial.print("<raw_gyro_x>"); Serial.print("<"); Serial.print(gyro_raw[0]); Serial.print(">");
Serial.print("<raw_gyro_y>"); Serial.print("<"); Serial.print(gyro_raw[1]); Serial.print(">");
Serial.print("<raw_gyro_z>"); Serial.print("<"); Serial.print(gyro_raw[2]); Serial.print(">");
Serial.print("<raw_acc_x>"); Serial.print("<"); Serial.print(acc_raw[0]); Serial.print(">");
Serial.print("<raw_acc_y>"); Serial.print("<"); Serial.print(acc_raw[1]); Serial.print(">");
Serial.print("<raw_acc_z>"); Serial.print("<"); Serial.print(acc_raw[2]); Serial.print(">");
Serial.print("<raw_mag_x>"); Serial.print("<"); Serial.print(mag_raw[0]); Serial.print(">");
Serial.print("<raw_mag_y>"); Serial.print("<"); Serial.print(mag_raw[1]); Serial.print(">");
Serial.print("<raw_mag_z>"); Serial.print("<"); Serial.print(mag_raw[2]); Serial.print(">");
Serial.print("<mean_gyro_x>"); Serial.print("<"); Serial.print(gyro_in[0]); Serial.print(">");
Serial.print("<mean_gyro_y>"); Serial.print("<"); Serial.print(gyro_in[1]); Serial.print(">");
Serial.print("<mean_gyro_z>"); Serial.print("<"); Serial.print(gyro_in[2]); Serial.print(">");
Serial.print("<mean_acc_x>"); Serial.print("<"); Serial.print(acc_in[0]); Serial.print(">");
Serial.print("<mean_acc_y>"); Serial.print("<"); Serial.print(acc_in[1]); Serial.print(">");
Serial.print("<mean_acc_z>"); Serial.print("<"); Serial.print(acc_in[2]); Serial.print(">");
/*Serial.println("<mean_mag_x"); Serial.print("<"); Serial.println(mag_raw[0]); Serial.print(">");
Serial.println("<mean_mag_y"); Serial.print("<"); Serial.println(mag_raw[1]); Serial.print(">");
Serial.println("<mean_mag_z"); Serial.print("<"); Serial.println(mag_raw[2]); Serial.print(">");*/
Serial.println("<att_p>"); Serial.print("<"); Serial.println(att[0]/3.14*180); Serial.print(">");
Serial.println("<att_t>"); Serial.print("<"); Serial.println(att[1]/3.14*180); Serial.print(">");
Serial.println("<att_f>"); Serial.print("<"); Serial.println(att[2]/3.14*180); Serial.print(">");
Serial.println("<acc_n>"); Serial.print("<"); Serial.println(acc[0]); Serial.print(">");
Serial.println("<acc_e>"); Serial.print("<"); Serial.println(acc[1]); Serial.print(">");
Serial.println("<acc_d>"); Serial.print("<"); Serial.println(acc[2]); Serial.print(">");
Serial.println("<vel_n>"); Serial.print("<"); Serial.println(vel[0]); Serial.print(">");
Serial.println("<vel_e>"); Serial.print("<"); Serial.println(vel[1]); Serial.print(">");
Serial.println("<vel_d>"); Serial.print("<"); Serial.println(vel[2]); Serial.print(">");
I then built a LabVIEW VI that will display the received data:
now, everything works great, but it occurred to me that I have no control over the speed of communication, so if the arduino is transmitting faster then the LabVIEW VI is receiving, I'll start gating outdated data, and mybe after a while even fill the buffer.
How can I solve this problem and make sure I always get up-to-date data?
Are there libraries that will use more advanced (synchronous) serial communication protocols over the usb?
Thank you for your input!
